« 1 (2) 3 »
Re: Brake upgrades
From Sydney
1200rallycar wrote:
biggest master cylinder = urvan 15/16"
best booster = sunny (b310)
but urvan master is probably too big ........
I run this master cylinder on my coupe, works great. it matched up with 180B booster.
At first i ran it with the stanza brakes, but now i run R32 skyline front rotors and 4-spot sumitomos.
I have never looked back since.
Cheers
Posted on: 2003/2/21 11:05
Re: Brake upgrades
From Warwick, QLD
hey benny, with the R32 rotors, can they attach to the stanza struts of sdo you need teh R32 struts as well??
Also is fitting the sunny booster easy or will it require many mods??
Cheers
Damo
Posted on: 2003/2/21 11:29
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Brake upgrades
From Melbourne, Australia
the sunny booster can be mounted two ways
1. cut firewall hole bigger
2. put spacer in so you dont have to cut firewall hole bigger
the second is better if you can make a spacer up, you may also need something in the way of a spacer to put master on as bolt holes might not match
i had a sunny booster and urvan master which mated but my bro-in-law got same thing and they didnt
my bro took the master for his esky and ive still got the booster but i dont really want it at this stage, ive still got stanza brakes
myplans are for pintara discs (need some machining to install) and hi-lux 4 spot calipers for the front and bluey disc over drums for the back, but i cant do that till i can afford 14" rally tyres
Posted on: 2003/2/21 11:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Brake upgrades
From Perth
I'm 110kg so I don't need a booster in a little car
Though I did upgrade the old 1000 to vented discs
http://www.users.on.net/ovington/techinfo/1000brakeupgrade.shtml
Posted on: 2003/2/21 12:19
Re: Brake upgrades
Some people prefer to pass the braking pressure/stress through the pedal box.
This is not good as you can bend the standard 1200 brake pedal (it's possible) under heavy braking load. A Booster also helps protect against this.
hehe. That describes my old "whale" 510 Wagon (Datsun 1600 wagon). First, the early 510 brakes weren't powerful enough to lock up on dry pavement. Second, for normal driving I had to apply amazing amount of force to the pedal. For more than the usual stop, I literally stood on the brake pedal (raising myself off the seat!). The pedal was a little bent, but never broke.
Looking back now, I see it would have been much safer to have a booster to take the force off the pedals. And bigger brakes would have been safer yet.
My 2-dr 1200 always had easy pedal effort even w/o booster.
Posted on: 2003/2/21 21:45
Re: Brake upgrades
Not too shy to talk
From k faffs OR
i would agree that recers like brakes wiht no booster having growne up racing camaros that weihgt some where around 3600 to 4500 pounds with
out nne to feel what the car is doing
the first time into turn 1 was interestingto say the least
Posted on: 2003/2/22 5:48
cant wait to race
Re: Brake upgrades
From Sydney, Australia
Hi Jimmy,
Are you saying that first turn in your 1200 it was good or bad?
My 4 wheel drum equipped 4dr 1200 is dangerous to drive. I've fully reconditioned the drums and wheel cylinders..it's still crap It's only a single circuit system too.
The secret to safety..Don't go any faster than 40mph ..or get bigger brakes.
Chris.
Posted on: 2003/2/22 6:42
Re: Brake upgrades
From Castro Valley,CA USA
with a smaller diameter master cylinder...wouldn't you have more hydraulic leverage? The trade off would be more pedal travel.
I had installed larger b210 rear wheel cyl (13/16") instead of the stock 1200 wheel cyl (11/16) and the rear wheels would lock-up with ease. (yes, i eventually spun out on the freeway and hit a gaurdrail before i changed them back)
I plan on installing the larger front brakes from a 210/b310 and the larger rear wheel cylinders and retain the stock 1200 master cylinder. Basically, 210/b310 with a smaller master cylinder. As long as I have enough pedal travel, the brakes should sqeeze harder with less pedal pressure. yes?no? maybe so?
Posted on: 2003/2/22 10:08
Re: Brake upgrades
you want th back to lock up first ....
.... if your rallying
Posted on: 2003/2/22 13:51
1200 Coupe Rallycar
Re: Brake upgrades
Not too shy to talk
From k faffs OR
its my brother who has the 1200 i have a b210 his car scares tne bjesus out of me i cant bet the hang of right hand dirve you dont see many here in the us so i get on the brakes hard alot i think a car that is 28 to 30% lighter then my 210
should respond better with 210 brakes yea
Posted on: 2003/2/22 18:28
cant wait to race
« 1 (2) 3 »
