« 1 ... 4 5 6 (7) 8 9 10 ... 21 »
Re: A-Series Manifold Templates for Autocad - Come n get 'em
From Perth Western Australia
ok sign me up!!
I'm also keen for that group shipping to perth - will see if the transport company i use for work picks up in SA on the way from melb - might make a big diff from AusPost prices - only prob is people would have to pick up from me!?
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval)
Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval)
LAGWAGON: I: 1 E: 1
boofhead: I: 1 E: 1
Grunterhunter I: 2 E: 1
Tnpshow I: 1(MS) E: 1
ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style
Ianey I: 1 alloy 1 steel E: 1
Sidedraught 2x mild steel exhaust
kue1000 I:1Alloy E:1 steel - oval
Posted on: 2007/4/3 18:51
From Adelaide, SA
Ang,
Can you give me the thickness of the flange at the bottom?
Posted on: 2007/4/3 21:26
Since i feel like being nice. A word of advice. The one piece exhaust flange (as pictured below) will aide in future manifold fit up. Just check out joys of a old holden straight 6 if you feel the need to seperate the flange.
But my main reason for this post. - the arrows drawn below. Make note of the shape under the exhaust port for cylinder 4. Failure to add this shape to the flange will make the manifold unable to fit smallblock A series unless its to be cut.
Posted on: 2007/4/3 22:05
From Adelaide, SA
Yep and that's precisely the reason for my concern about clearing the block - that area imparticular.
I have an A10, old school A12, A14 and an A15 block to test against, not to mention CNC milling and laser cutting abilities at work to test my designs against (laser cutting stops at acrylic and thin fibreglass - no metal unfortunately).
Hopefully I will get to cut a one piece test tomorrow on a piece of acrylic.
PS - If anyone wants to test one on their head, let me know - I'll mail you one! (not too many though )
Posted on: 2007/4/3 22:57
From Perth
Sorry mine is all fitted up at the moment, but that back section was only tight for me when i had 3.5mm shaved off the head and then it only took a small amount of grinding to fix. but i had no problems with the inlet manifold. The bottom brace helps in keeping the exhaust outlet aligned.
Posted on: 2007/4/5 12:16
From Castro Valley,CA USA
The thickness where you have arrows is about 12mm /
Posted on: 2007/4/5 14:32
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
LAGWAGON: I: 1 E: 1
boofhead: I: 1alloy 1steel E: 2 (oval ports)
just changed mine and a bump as well
Posted on: 2007/5/1 4:48
From Tasmania
Is this still going to happen or has every one already got there bits.
I dont want to add my name to the list if its all been done already.
Posted on: 2007/5/7 13:02
Proud member of " The Tasmanian Datsun Owners Group"
From Adelaide, SA
No it's still happening i'm just waiting on a sample to verify the latest exhaust design.
After I get that back it's all go!
Posted on: 2007/5/7 13:12
From Melbourne, Australia
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
LAGWAGON: I: 1 E: 1
1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel
Posted on: 2007/5/7 15:32
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
