« 1 2 3 (4) 5 »
Re: Rebuilding a 1200 ute
From Far, far away
That's what those blokes with clipboards will do to ya!
I thought you could pretty much do anything to a car in the shaky isles? I've heard of street registered cars with half chassis' and ladder bar rear ends over your way. If that's the case your man should have no worries OK'ing a twin turbo small block.
If you go this way you may need to start wearing brown undies though.
Posted on: 2007/4/15 5:19
Quite a regular
From Christchurch
he's ok with the tube front end but it has to be completely redesigned. In other words cut off and started again. Still thinking about a motor. There is a guy in nz putting a lexus in his ute i will hunt down the link. Now that would be fun 200 kw plus in a light ute
Posted on: 2007/4/16 1:17
From sydney,
if your looking for a new grille.. or new front fenders .. have a look on ebay.. coz i know they have fenders and a grille up there now.. and they arnt to expensive!!
good luck!
Posted on: 2007/4/16 3:52
Quite a regular
From Christchurch
some pic's of the tube front end
Posted on: 2007/4/16 9:42
Quite a regular
From Christchurch
small update decided to cut out the back end of the ute and change the sub frame from welded in to bolt in. I am glad i cut it out the welding was shocking could lift one coner and the other three would still touch the ground. So spent most of the weekend cutting and grinding and my camera f**k*d it self as well.
Posted on: 2007/4/22 20:34
Quite a regular
From Christchurch
ok bit of an update got the rear chassis made so that the rear sub frame can be bolted and unbolted. doesn't look like much but lot's of messing round. Moved the sub frame back 3/4 of an inch.Picking up this weekend 2 front guards bonnet and tail gate for the ute.
Man with clip board was happy with the rear end just got to figure out what to do with the front end.
here's a pic of the frame in the car and nowOpen in new window
Posted on: 2007/5/1 0:59
Quite a regular
From Christchurch
ok an update found out that the old body was f**ked. Went out and found another one. As shown in the photo that is going to be now far off the ground it will be sitting once it's finished :).
Posted on: 2007/8/2 2:21
From Canberra
This looks sooooooooooo much better. Those flares on the old one were...
different
Posted on: 2007/8/2 2:41
From perth airport
orrrrrr wat no flares :( wat was wronge wit the last body ?
Posted on: 2007/8/2 2:44
perth airport parking
Datsun 1200 ute A14
Quite a regular
From Christchurch
No still going to have flares but not like the last ones.
The last body was full of bog rust and not one of the panels where straight. there was not much right with it
Posted on: 2007/8/2 12:11
« 1 2 3 (4) 5 »
