diff ratios
From Wagga Wagga nsw australia
is it possible 2 change the diff raitos so that it has a higher top end spend??
Posted on: 2007/4/26 7:53
Re: diff ratios
From sydney
The answer is yes, what is it you have and what ratio has it got now? (if you know)
Posted on: 2007/4/26 7:55
Re: diff ratios
standard a12 1980 ute diff.. not sure what the ratio is. what swaps hav other people done to get a higher ratio?
Posted on: 2007/4/27 2:09
Re: diff ratios
From Geelong, Vic
standard ratio will be 4.11
you can get 3.9s from most bluebirds and jap stanzas
and you can get 3.7s from the 4 speed 4 door series 1 or 2 bluebirds
Posted on: 2007/4/27 2:29
Re: diff ratios
From Christchurch NZ
really? I didn't know there was an 3.7:1 h165!
Posted on: 2007/4/27 3:03
Forced Induction!
Re: diff ratios
From Geelong, Vic
well now you do
Posted on: 2007/4/27 3:07
Re: diff ratios
Sounds like you have been wagging 1200.com school or not paying attention.
Stay in after class & read more Wiki notes
Posted on: 2007/4/27 3:08
Love your Datsun.
Treat it well.
Re: diff ratios
so how dificult is it to change the diffs. does it make a noticable difference? as i bairly use my 1st gear
Posted on: 2007/4/27 3:15
Re: diff ratios
From Geelong, Vic
not really hard to do
take the axles out
undo tailshaft
pull 4.11 centre out
put 3.7 centre in
and yes you will notice the differance....my 1200 was a 3 speed when i first got it too
Posted on: 2007/4/27 3:18
Re: diff ratios
Guilty!
Posted on: 2007/4/27 3:41
Forced Induction!
