« 1 (2)
Re: Hydraulic clutch conversion
From NSW, Australia
Very nice peformace upgrade with that Clutch cyclinder hey. Would any one know if its possible to convert the 1200 A series box to Hydralic ?. I have always had hydraulic clutches on my Datto's and my 1200 is the first Cable set-up owned. (Not a Fan)
Any info would be great.
Posted on: 2007/5/2 15:34
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Christchurch NZ
bigD,
If you look on the otherside, underside of your bell housing, You'll see an oval shaped knockout panel. This was where the LHD datsuns had the cluch set up. If you were really keen, you could convert your box to hyraulic. Or find a gearbox from a LHD car.
Posted on: 2007/5/2 16:33
Forced Induction!
From Bris-Vegas
My setup: -
I just drilled the holes too... Added a bit of extra bracing to the steering column though as the firewall was flexing a bit.
Posted on: 2007/5/2 20:40
CA18DET '74 1200 ute project
« 1 (2)
