« 1 ... 7 8 9 (10) 11 12 13 ... 21 »
Re: A-Series Manifold Templates for Autocad - Come n get 'em
From Adelaide, SA
What about doin the oval intake ports for a GX head? The GX heads have bigger ports than the A14/A15 ovals do
Hang on a minute - are you saying GX intakes are like standard round port stud patterns with ovular ports instead??? oh, no these are A14 / A15 oval ports - sorry for the confusion!
will the weber flanges be available as part of the group buy laser cutting ???
Uh...mmm... do we want them?
Posted on: 2007/5/10 22:59
From South Africa, Bloemfontein
As far as I know, the GX cylinder head uses the same bolt pattern as the A14/A15 oval port cylinder heads. I am just not sure if the ports sizes are the same or different between the GX cylinder head and A14/A15.But as mentioned, nothing a di grinder can't fix.
The round ports use then their own bolt pattern that are different to the oval port heads.
A question about the grade of aluminium for the intake manifold. What grade would you guys suggest? The laser cutter says they use 10something.
I think it is too soft.Must I then rather go mild steel?
Posted on: 2007/5/10 23:44
1977 Datsun 1200GX
From Perth
I want a pair of weber flanges please
Posted on: 2007/5/11 1:24
From Invercargill, New Zealand
Rally1200 I:2 E:2
Dattoman_1000 I:2 E: 2
dattodevil I: 1
pager I: 1 E: 1
Beattie I: 2 (1 steel braced, oval & 1 alloy braced, oval)
Cable_tie I: 3 alloy 2 Mild E: 5 (all Oval)
LAGWAGON: I: 1 E: 1
boofhead: I: 1alloy 1steel E: 2 (oval ports)
Grunterhunter I: 2 E: 1
Tnpshow I: 1(MS) E: 1
ang94541 I: 1alloy oval, 1steel oval E:3 rally1200 style
Ianey I: 1 alloy 1 steel E: 1
Sidedraught 2x mild steel exhaust
kue1000 I:1Alloy E:1 steel - oval
1200Rallycar I: 1 alloy 1 steel (oval ports) E: 2 steel
Wombat Racing 1 ovalport inlet, 2 exhaust
Teretonga I: 3 alloy (oval ports) E: 3 steel
Dundee1000 1 alloy oval, 1 Steel exhaust.
picko: 2 exhaust, 2 intake
Posted on: 2007/5/11 8:36
From Tasmania
I to would be interested in the weber flanges.
Posted on: 2007/5/11 8:48
Proud member of " The Tasmanian Datsun Owners Group"
From VIC, bendigo.
YES PLEASE!!
Rally1200 I:2 E:2
dattodevil I: 1
pager I: 1 E: 1
LAGWAGON: I: 1 E: 1
Trickdat I: 1 alloy 1 steel (oval ports)
Posted on: 2007/5/12 8:46
1200 Sedan.Turbo A14 drawthrough 15psi Meth inj 104rwkw
1200 coupe club car. turbo L20 drawtrough
From Adelaide, SA
WARNING!
Ok people, I've checked a few different heads with a laser cut sample and I'm getting some drastic different variances in castings!!!
One head I have, #2 and #4 are 1mm shifted to the left, another head I looked at (A14 Pulsar oval port), all the ports (intake AND exhaust) were 2mm higher than another I measured!!!
So... where do we go from here? Do I make the ports small enough to cater for the majority?
This would mean that everyone would have to grind the templates to suit their head...
I don't know what to do - whats the general consensus?
Posted on: 2007/5/12 18:15
From Perth
Can you do them as a pdf we can print out at correct size and check our heads ?
Posted on: 2007/5/12 18:59
From Adelaide, SA
A3 Size PDF available HERE
Cheers,
TC
Posted on: 2007/5/12 20:49
From Melbourne, Australia
makes you wonder...
how often i've just chucked on an oval port manifold thinking she'll be right
and they are probably out of alignment now and then....
Posted on: 2007/5/12 21:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
