Electronic ign, a15, bosch coil???
From The garage, NZ
Hey all.
A little while ago i unveiled my race prepped a15.
It has come a fair way and soon (hopefully) will be fitted to the datto.
Now, in looking for a coil i came across the bosch gt40rt.... sounded really good. it says it needs to be used in conjunction with a ballast resistor, no problemo.
Anyone have anything to say about these coils?
My a15 has an electronic distributor if it helps.
I am unsure of what it actually is or where it came from though as i got it with the engine.
It has a set of numbers across the base however.
I was going to get this bosch gt40rt coil and ballast resistor and use that but i want to know what others think first.
Heres a few teasers:
Cheers guys
Cheater
Posted on: 2007/5/12 16:15
Re: Electronic ign, a15, bosch coil???
From Perth
I also tried the GT40rt
bad move
HEC715 I think I ended up with
The 40 wouldn't allow it to idle properly
Posted on: 2007/5/12 16:18
From The garage, NZ
really... wow.
have you tryed any other coils?
Posted on: 2007/5/12 16:23
From Christchurch NZ
Is your head an H72, or an a12 round port that has been ported out big time? I can't see any any water galleries under the intake ports.
Posted on: 2007/5/12 17:15
Forced Induction!
From The garage, NZ
i asked marsh what he thought and he rekoned sunny head. i wasnt really thinking much so didnt ask a12 or a15 lol. i will ask him again though.
There are both things that suggest a15 and things that suggest a12 its a hard one.
Out of interest what coil are you using a14force ?
Posted on: 2007/5/12 17:25
From Ipswich, QLD
your head looks like it might be an A12- the manifold bolt spacing is probably the easiest way to tell. There's a bolt hole in between each inlet manifold hole, this means it was originally a rond port, so a12 it most likely is!ty
Posted on: 2007/5/12 17:45
From The garage, NZ
cheers yea i did think that, prob the easiest indeed.
Coils... anyone else? what have you used?? thats right, you!
Posted on: 2007/5/12 18:09
From In front, and pulling away.Sometimes around Sydney....ish!
I use the coil out of a pulsar that was fitted with electronic ignition.
Posted on: 2007/5/12 21:24
Lifes good when your on BOOST!
stick with the oil filled type ... they self cool better than the little ones.
i run a gt40r ?? i think, no ballast resistor one, and using a modded bosch bluebird elec dizzy ... never had a problem
the non oil coils have a tendancy to over heat when giving them a flogging and once they cook, in less than a blink of an eye it's all over ... no more spark
Posted on: 2007/5/12 21:44
From The garage, NZ
oh true. thats kinda wierd since i thought they were a step better than the standard coils of most cars.
Posted on: 2007/5/13 4:41
