Browsing this Thread:
1 Anonymous Users
Chickenhawk update |
From Fort Worth, Texas, USA
Tensandtwenties has just about got me convinced to put the VG-33 V6 behind the seats in the Chickenhawk. By using a Maxima 5-speed transaxle, we'd build a mid engine, V6 1200. What are some of your thoughts on this scheme? I know we have discussed this before, but i didn't want to drag up an old post.
Posted on: 2003/3/7 21:09
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
Re: Chickenhawk update |
Registered Users Contentmaster Usermaster
What's wrong with dragging up an old post, if it's on topic?
Anyways, I say go for it. It would be interesting and definitely not a cookie-cutter recipe.
You might need to rename it "WheelieHawk" with little weight up front and all that torque ...
Posted on: 2003/3/7 21:41
From Pakistan
its possible if u ask me, as i have this in mind too :)
BUT what will u do to make rear tires rotate in right direction? as u must know all the 5 gear will b Reverse gears when u put engine and trasaxle in the car. barpk
Posted on: 2003/3/8 8:32
STRONG IS STRONGEST ALONE. PERIOD
Just move the entire Maxima front-wheel-drive powertrain unit and front suspension back about 5 feet, then replace the Maxima with a 1200 ... since the engine and transaxle are a unit the the wheels will still turn the same way.
Or was Dimlight thinking of something else?
Posted on: 2003/3/8 8:40
From Pakistan
Quote: ddgonzal wrote: Just move the entire Maxima front-wheel-drive powertrain unit and front suspension back about 5 feet, then replace the Maxima with a 1200 ... since the engine and transaxle are a unit the the wheels will still turn the same way.
to make a MR car engine needs to b between axle and driver, u r talking about a porsche like setup. Whole axle-engine assembly will be turned 180 degree to get a MR car. this will b better then getting porshe like steup for weight dustribution, handling charectaristics and exotic appeal. but it could prove more difficult. barpk
Posted on: 2003/3/8 8:58
From Melbourne, Australia
hes talking about using a fwd box!
bro was looking at lada niva today, pointed out that there is a tailshaft between gearbox and transfer case, this means it could be used easily on any gearbox with a modified tailshaft, now all you need is the tunnel out of the niva and to rearrange the front end and you have a 4wd car!
food for thought
Posted on: 2003/3/8 12:48
From Christchurch New Zealand
why dont u use a MR2 motor and box scince they are allready an MR car plus they are supacharged
Posted on: 2003/3/9 2:22
"If your not living on the edge your taking up too much space" Rod Millen
Rally-a-coupe, I'm using the V6 because I have a very low mileage engine out of a crash test car, thanks again John.
Barpk, I'm not sure what gearbox you are talking about. The FWD V6 Maximas we got had the engine sideways and just slightly in front of the transaxle.
Posted on: 2003/3/10 18:29
From Arlington, TX, USA
Quote: rally-a-coupe wrote: why dont u use a MR2 motor and box scince they are allready an MR car plus they are supacharged
Because the VG33E makes more power without the SC. And we can always turbocharge it later? And it's a Nissan engine? And.... A mid-engined set-up is identical to a FWD set-up, only mounted further back in the car.
Posted on: 2003/3/11 4:02
1973 Datsun B110 Coupe (A15/5spd) 1977 Datsun 280Zed (5.0L/5spd)
From Brisbane, Australia
the term 'transaxle' is not normally used in reference to fwd boxes. I think that's where the confusion came from.
You guys are talking about using the maxima engine and box mounted east-west in the rear of the 1200, not running the maxima V6 engine north-south and adapting it to a porsche style transaxle.
I think it's a very cool idea, but what would you use it for? over here you'd never register it for road use, and it wouldn't even be legal for any race category. maybe you could hillclimb it as a 'special' against the custom fabricated open wheelers, but you wouldn't be competitive.
Posted on: 2003/3/11 5:11
