(1) 2 3 »
Roller rockers
From Mie Japan
Hi guy's,
Roller Rockers question?
Which of Bush and the bearing thinks the part center part to be good?
cheers,
Posted on: 2007/5/26 8:34
Re: Roller rockers
These rockers are better known as 'roller tipped' & are very good. They remove, or at least reduce the side load on the valve stems & the alloy body reduces the inertia, thereby allowing higher RPM without stiffer springs, but..........................
True roller rockers, the ones with roller bearings on the shaft are the best of them all. The Yella Terra brand ones that are made here in Australia do not have colour anodising as this [allegedly] reduces the strength of the alloy & they come as a complete rocker assembly with a higher lift ratio of 1.54 to 1 compared to the 1.44 to 1 of the standard rocker arms.
These are Ferals rockers, & it's a good shot showing the whole kit.
Posted on: 2007/5/26 9:15
Love your Datsun.
Treat it well.
Re: Roller rockers
From Freo
Deffinately the Bearing shaft would be better,
the ease of fitment of the JB ones as a direct replacement should make them ok, and they should be chaeaper, although not the case..
Posted on: 2007/5/26 9:27
Re: Roller rockers
Yeah, I was surprised that the JB ones were only about $100 cheaper, so when you look at what you are buying for the extra $100 when selecting the Yella Terra units, it looks to be a real bargain.
P.S. My price comparison was done when I bought my own Yella Terra ones a couple of years back.
Posted on: 2007/5/26 10:24
Love your Datsun.
Treat it well.
Re: Roller rockers
From Perth WA
How much are roller rockers?
Not that im interested atm though...
Posted on: 2007/5/26 10:30
Chris...
Re: Roller rockers
From Sydney Australia
Hi Sunny coupe thanks for your pictures! I was looking through your album and found this, I was just wondering if that is an xd ford in the background? I didnt think you had them in Japan?
cheers
Posted on: 2007/5/26 10:49
Re: Roller rockers
From Perth WA
Hahaha that looks like Mike (Dundee1000)'s place!
Posted on: 2007/5/26 10:52
Chris...
Re: Roller rockers
haha well that would explain it!
Posted on: 2007/5/26 10:59
Re: Roller rockers
From Perth
I've ordered some roller rockers for someone
Anyone else want any while I'm at it ?
$770 ... maybe less if we order more.
Posted on: 2007/5/26 12:14
Re: Roller rockers
From Burbank, CA
$770? I thought they were way less. How much is a set of yella terra ones? if it's not $700 that might be a vet good part to buy for the future...
Posted on: 2007/5/26 16:43
|||\ 81 KPB310 /|||
(1) 2 3 »
