a15 crank into a14 block
Quite a regular
From Geraldton, west aus
Can you put a a15 crank into a a14 block?
and is there any difference between the a14 and a15 heads?
Posted on: 2007/5/30 16:10
Re: a15 crank into a14 block
tiger90 wrote:
1. Can you put a a15 crank into a a14 block?
and
2. is there any difference between the a14 and a15 heads?
1. Not without custom pistons & other mods, but you can use an A14 crank with stock parts & relatively little work.
2. In practical terms, the two heads are essentially the same for Ausrtalian domestic models. There is a round port head that was used in the US & elsewhere, & some of these heads/engines have found there way here through the years.
EDIT
Doh,.... I thought the question read A15 crank in A12 block. My appologies for dumb response.
A14 & A15 blocks are dimentionally interchangeable.
Posted on: 2007/5/30 20:29
Love your Datsun.
Treat it well.
From NSW South Coast
A15 crank fits fine. You need the A15 pistons, rods are the same as is everything else except the sump. The bigger crank hits on the A14 sump.
olboy
Posted on: 2007/5/31 7:34
From Perth
My engine is A14 block and A15 crank
No sump clearancing required on mine
Rods are same length as mentioned
A15 pistons
Essentially your building an A15
Posted on: 2007/5/31 11:42
From Townsville, Qld
Has anyone ever thought about those A15 pistons? they're the reason the motor has less compression than the other A series motors
Posted on: 2007/5/31 12:18
Quite a regular
whats the difference between a14 and a15 pistons?
Posted on: 2007/5/31 12:52
From Perth
A14 have a pin height (centre of gudgeon to top of crown) of 32.5mm
A15 has 30mm
If you put A14 pistons with an A15 crank the pistons will stick outthe top of the bore by 2.5mm
Posted on: 2007/5/31 13:30
Sorry, stupid response earlier on my part. Correction included in my earlier post.
Posted on: 2007/5/31 14:11
Love your Datsun.
Treat it well.
