clutch fork comparisons
From The garage, NZ
I need to know if the 56 series clutch fork is the same as the 60 series. i think i asked a question on here before with no avail.
SO, i have a picture of a 60 series clutch fork and im hoping someone has a clear picture of a 56 to compare.
Anyway here is the 60:
any info or direction would help, also real keen to see a pic of the 56 fork.
Cheers
Posted on: 2007/6/20 21:13
Re: clutch fork comparisons
From SE Melbourne
I took a butt load of pics of a 60 series that I pulled apart. It is A14 Prep page 10 on my dodgy website.....see if anything there could help.
I think stooey47 on this site inherited all the pieces of the gearbox of me - I bet it still is in pieces too - he might be able to take a snap of something for you.
Posted on: 2007/6/21 3:00
Mildman, Datsunless
From The garage, NZ
the big problem for me is even if i had the 60 series fork in my hands... i still need to remove my 56 out of the car to check.
Basically im looking for someone who has a picture of the 56 series fork that i can make comparisons too.
the picture i put up in the first post is from a 60 series.
I'll give your site a look.
Posted on: 2007/6/21 4:47
From Quairading, Western Australia
I have a 60L behind an A12 - the only difference to put a 60L behind an A14/A15 iis to use the long thrust bearing holder
I think my 60L uses the long TB holder as it's behind the A12 in "The Defect"
no I'm not interested in selling my 60L 4 speed... or swapping/giving it awayas it will be pressed back into service soon
Posted on: 2007/6/21 5:55
From The garage, NZ
so, "long thrust bearing holder" for when behind a12 or a14/15 ?
Also the long tb holder comes from.....? which box.
Posted on: 2007/6/21 6:26
From Christchurch NZ
Chris, postage will be $5 max. I'll send you my fork, and if it's not what you need toss it away.
Posted on: 2007/6/21 6:41
Forced Induction!
From In front, and pulling away.Sometimes around Sydney....ish!
Ok, clutch fork for 56 series box is almost straight and uses longer thrust bearing holder. 60 series use a fork with almost a 90 degree bend in it with a shorter thrust bearing holder. I know this as I just spent the last 3 days pulling the gearbox in and out to sort the issue!
Posted on: 2007/6/21 7:04
Lifes good when your on BOOST!
I'm assuming the long TB holder comes from an 56A - and the short one comes from an 60L
the difference id because the A14/15 flywheel is thicker
I'm assuming my 60L has a long one as it's behind an A12
Posted on: 2007/6/21 7:32
From The garage, NZ
YAY. after painfully wearching both the internet and 1200.com for both images of the 56's and 60's and info on them i found a thread that datrat dave had put up and i think it solves me problems.
link to thread for future reference
also found a thread that dattodevil has posted ages ago.
good info there.
linkey
Posted on: 2007/6/21 10:01
From The garage, NZ
more history of maybe wrong carrier ??
link
Posted on: 2007/6/21 10:07
