fuel probblems
Quite a regular
From West Auckland New Zealand
been haveing probblems with my 40mm dellortos on my a14 seams 2b over fueling!
am useing standard fuel pump at moment! think the standard pump is to higher pressure? am planing on puting a electronic fuel pump & regulator on!
but want 2 know what type of pump & regulator most people find best 4 this sort of set up?
Posted on: 2007/6/23 23:38
Re: fuel probblems
From SE Melbourne
Was just looking around for lift pumps and found Carter to be a good brand....apparently a little noisy. Pierburg are also meant to be OK...but hard to find.
I believe both of those brands are generally better than Holley.
Probably a stock 72gph type Carter would be all you needed.
Posted on: 2007/6/24 9:42
Mildman, Datsunless
Re: fuel probblems
From Christchurch NZ
Your needles and seats might be worn, or maybe the float levels are set too high.
Posted on: 2007/6/24 9:52
Forced Induction!
Re: fuel probblems
Quite a regular
yeah thanks 4 that! i was going 2 cheek the float levels this weekend! carbs were rebuild not long ago
Posted on: 2007/6/25 6:44
