« 1 ... 3 4 5 (6) 7 8 9 ... 11 »
Re: for sale:a series turbo manifolds
From Perth WA
J pipe is a posibility i spose...
Me and Neil have been talking about making something up to suit a 1000. We both have flanges coming and Neil has a welder. We could tack a manifold up to suit then get it welded/reproduced. Just buy a few bits of steam pipe... I can see it being cheaper that way too!
I just had a thought. Mike could we use one of your many 1000s in the 'graveyard' to mock this manifold up on? When are you gettin back from Malasia? You have PM anyway.
Posted on: 2007/6/25 12:58
Chris...
From WA
dude - just bring em round to me - i'll knock them up for you to whatever size you want.
i have got a place that sells steam bends cheap-cheap too.
Posted on: 2007/6/25 13:08
From Perth WA
coolio!
Ill give ya a buzz sometime tomorro. Either 10am or 1pm (smoko and lunch)
Posted on: 2007/6/25 13:24
Chris...
From Brisvegas, oz
So than its only 2mm thick?
no its 4mm thick as i said before
Posted on: 2007/6/25 22:27
www.camerasplus.com.au
You also wrote this before?
frankthedolphintrainer wrote:
its 1 inch pipiing so i guess its about4mm bigger than that
Also mentioned TIG welds?
I guess its a gamble or lucky dip at what you actually get.
Posted on: 2007/6/26 12:29
From Brisvegas, oz
what???
i think your reading skills are lacking. it reads correctly and you get exactly what ive written.
Posted on: 2007/6/26 21:58
From Melbourne, Australia
looks like a great manifold, im tempted to buy one for a simple turbo setup
would love to see a photo of one in an engine bay though
maybe a photo of the manifold with the manifold gasket sitting over it would give people a better idea how it is suited to the port size
Posted on: 2007/6/27 3:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisvegas, oz
you should be able to see one fitted to a few before soon cos ianey and dog180 should be getting theres tommorow
Posted on: 2007/6/27 5:12
From In front, and pulling away.Sometimes around Sydney....ish!
As soon as I get mine, I will TRY to post up pics (never seem to have any success?) with the gasket on and of one fitted in the engine bay. I will be doing an intercooled blow thru set up and I am hoping to EVENTUALLY get approx 165rwhp or so from the humble A series.
Posted on: 2007/6/27 6:48
Lifes good when your on BOOST!
what???
Without getting nasty champ, I can read clearly what you wrote.
"its 1 inch pipiing so i guess its about4mm bigger than that "
I read that its 1 inch ID and you clearly write its "4mm" bigger.
Well maybe educate yourself champ. 4mm thick pipe will be 8mm bigger in diameter.
So i can clearly read that you have written it is 2mm thick pipe.
Posted on: 2007/6/27 8:29
