Re: What is involved in fitting a hydraulic clutch?
From Portland, Vic
Thanks for your replies guys. At least now I know where I am heading with it. Pretty much the only thing I need is that master cylinder as the g/b I am getting should already have the slave cylinder. Do you think there would be enough room next the the brake MS (85 ute), or above it where the clutch cable comes out, to mount the clutch MS?
dattoman, what kind of prices would I be looking at for one of these master cylinders, and can you let me know of the dimensions, and also maybe the part/model number as I am very interested.
Thanks.
Leigh
Posted on: 2003/3/18 22:03
- 1985 Datsun 1200 Ute - S5 13b Turbo
Subject Poster Date
     What is involved in fitting a hydraulic clutch? Wattage 2003/3/18 0:44
       Re: What is involved in fitting a hydraulic clutch? ddgonzal 2003/3/18 1:55
         Re: What is involved in fitting a hydraulic clutch? Wattage 2003/3/18 4:30
           Re: What is involved in fitting a hydraulic clutch? ddgonzal 2003/3/18 5:15
             Re: What is involved in fitting a hydraulic clutch? dattodude 2003/3/18 6:07
               Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/18 12:04
                 Re: What is involved in fitting a hydraulic clutch? dattodude 2003/3/18 12:28
                   Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/18 14:00
                     Re: What is involved in fitting a hydraulic clutch? Wattage 2003/3/18 22:03
                       Re: What is involved in fitting a hydraulic clutch? dattodude 2003/3/19 7:10
                         Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/20 12:53
                           Re: What is involved in fitting a hydraulic clutch? Wattage 2003/3/20 22:16
                             Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/21 12:07
                               Re: What is involved in fitting a hydraulic clutch? 1200rallycar 2003/3/22 1:52
                                 Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/22 3:47
                                   Re: What is involved in fitting a hydraulic clutch? 1200rallycar 2003/3/22 3:59
                                     Re: What is involved in fitting a hydraulic clutch? 1200rallycar 2003/3/22 4:01
                                       Re: What is involved in fitting a hydraulic clutch? dattoman_1000 2003/3/22 5:31
