Thought id be nice and share some useful info
From The garage, NZ
being the nice guy i am, i thought some of you out there might want to hear this.
Its nothing big but it might help some of you.
I know it helped me.
Anyway, 1200 wheel studs and wheel nuts...
Maybe to short for some of your setups? maybe they have sh*t out and you want a cheap and easy fix.
s13 studs are the same thread, same diameter, and are infact longer by 10mm. If you cant find s13 studs then most laurels and cefiros have the same suspension/brakes so they can be used aswell.
I have laurel ones in mine as of today.
Also, s13/180sx brake conversions. Since laurel and cefiro have pretty much the exact same brake/suspension setups, the disks and calipers can be used from them for conversions.
Another helpful bit of info, in the s13/180sx brake conversion, you can use type x 180sx rotors as they are larger dia then the non type x's. Only down side is they wont fit under 13's.
Thats me for today.
Posted on: 2007/7/2 5:14
Re: Thought id be nice and share some useful info
From California
cheat you're just a giver!
Posted on: 2007/7/2 5:42
From Adelaide, SA
Ain't you a nice fella?
I would like to fit my Sigma Turbo riims to the ute but the studs are a little too short.
I wonder if I could swap the studs on my S13 and ute
...(kidding)
Posted on: 2007/7/2 6:41
From Christchurch NZ
Cefiro wheel studs are complete sh1t. They break off while you wait, and the gnurling that is intended to hold them in the hub doesn't.
Posted on: 2007/7/2 7:21
Forced Induction!
From The garage, NZ
more information i discovered today thati havnt found elsewhere.
The a12 alternator bracket (right hand side) does not fit the a15 block. the block doesnt have the required holes.
However, its still possible to mount it there.
Im using the a12 bracket, slotting the holes to fit and make the alt pulley in line with crank etc.
A12 and a15 drive belts arent the same length.(a15 = longer)
The coolant inlet at the bottom of the block (right hand side) is a different length on the a15 than the a12 making it hard to fit alt on a15 in a12 place.
I cut and welded my bracket to fit, easy.
Posted on: 2007/7/3 9:47
From Geelong, Vic
r31 pintara and skyline studs are probably the same length as s13....if not longer
Posted on: 2007/7/3 10:03
From Adelaide, Australia
They are the same as S13, 10mm more than standard.
Posted on: 2007/7/3 10:05
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
As far as i know all Nissan light vehicle wheel studs are the same M12x1.25, just the lengths that vary.
Posted on: 2007/7/3 10:57
When you say A12, do you mean 1974 & later A12, or 1970 to '73 Datsun 1200 engine?
You also mention a coolant inlet on the right side of the engine, but there is no coolant inlet on the right, It's on the left of the engine.
From what I can make of it, you are probably trying to use the alternator bracket from your original 1200 engine, which is mounted on the left side of the block, & trying to fit it to the airconditoner compressor mounting boss' which are also on the left side of an A15 engine.
Different setup altogether & as you have discovered, it won't fit up.
The [1974 onwards] A12 alternator, is of course in the same place as the A15.
Right & left are always determined as if siting in the car unless specifically mentioned otherwise. After all, our cars are 'right drive'.
Posted on: 2007/7/3 11:28
Love your Datsun.
Treat it well.
geeez and all this time ive always swapped hoses on my a155 with a12 ones... seems most afetermarket parts are similar lenght dfor a series (ooh i mean the later 120y style mid dizzy version with the alternator braket on the australian drivers sdie that does fit on an a15 too)
Posted on: 2007/7/3 11:35
