« 1 2 3 (4) 5 »
Re: Checker Plate
From Townsville, Nth Qld
u find any sites with pics of what and how others have done it? would be interested 2 c work involved...
Posted on: 2007/7/5 2:28
Cheers
Davo
Re: Checker Plate
From Geelong, Vic
not that hard to remove the tub floor....and really easy when you dont want the chassis rails
but when i did my ute i just used an air chizel to rip through all the spot welds that hold the floor to the chassis rails
a neater way to do it would be to grind most of the way through where the spot welds are then just pop them off
would make it easier if you cut the big flat sections out first with a 9 inch, then you can see where chassis rails and stuff are easier
heres a pic from the early stages of irs conversion....can see all the bare chassis rails
Posted on: 2007/7/5 3:27
Re: Checker Plate
cheers PIGDOG,
how different would it b for a ute that has had it's rear wheels tubbed?
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=13407[/img]
Edit - well that didn't work did it
Edit - AH HA! got it that time
cheers PIGDOG...
Posted on: 2007/7/5 4:01
Cheers
Davo
Re: Checker Plate
From perth airport
looks like it could get messy if ya dont know wat your doing
Posted on: 2007/7/5 4:02
Re: Checker Plate
From Geelong, Vic
you want to copy the url in the properties of the pic
but why would you want to cut the floor out...looks ok
with the tubs you would just have to cut around them as they most likely wouldnt be spot welded
oh and i didnt really know what i was doing when i cut the floor out, but its not hard to learn... chassis rails dont get cut
Posted on: 2007/7/5 4:06
Re: Checker Plate
i was just curious what others had done, not necessarily gonna do it... just like to know as much as possible so i have options 4 future... (can neva know 2 much) i was actually thinking o just checker plating the little side panels n the panel u c right in front o u in middle...
any thoughts?
Posted on: 2007/7/5 4:14
Cheers
Davo
Re: Checker Plate
Quite a regular
From Western Sydney
I personally would just layer over the top, the flat section leaving the wheel arches and sides alone.
I like the look of the rounded wheel arches and I don't think checker plate would suit such a look,I prefer a box look with checker plate.
Posted on: 2007/7/5 5:00
Re: Checker Plate
yeah i didn't plan 2 touch wheel arches or any o that, just flat area... didn't wanna go ova board...
K.I.S.S principle that's the way i work
Posted on: 2007/7/5 5:09
Cheers
Davo
Re: Checker Plate
From perth airport
k.i.s.s ?????????
Posted on: 2007/7/5 5:43
Re: Checker Plate
Keep It Simple Stupid (K.I.S.S)
Posted on: 2007/7/5 6:11
Cheers
Davo
« 1 2 3 (4) 5 »
