Guys,the toyota box i"m sure is the only viable alternative.I reasearched this for months before finally deciding,but opted not to go with the dellow but to do our own.
Put very simply,we cut part of the bell housing off a stuffed 60 series just behind the clutch fork hole,Tig welded an alloy plate to this face and bolted thru to the toyota box,we also opted for a spicket bearing in the flywheel as opposed to the crank(easier)before welding on the plate we also rotated the box as the toyota lays over to ease fitment.
But alas it still was not going to go into the tiny tunnel,so we cut it out and installed a section from a sunny automatic,problem solved.The cost of this experiment including gearbox and all the other bits,RPM toyota sprinter clutch etc.etc.was around $1200.00
This all sounds really simple,but when you are breaking new ground expect the un expected and a few stuff ups along the way,but the end result was worth every cent.
It almost seems a shame now as the car only has 2 events left now before the official For Sale sign goes up.
