« 1 (2) 3 »
Re: brake upgrade
can R32 front strut fit in a B310? it got 320mm disc rotor
Posted on: 2007/7/12 9:00
Re: brake upgrade
From Geelong, Vic
maybe but i doubt it, fitting a wheel might not happen without having huge flares
r32...320mm disc? brembo calipers?
most of them have a 280 or 296mm disc
Posted on: 2007/7/12 9:13
Re: brake upgrade
Posted on: 2007/7/12 9:25
Re: brake upgrade
From Wagga Wagga, NSW
how heavy are 280zx/r31 struts compared to stanza/200b struts?
and also what contol arms ball joint radius rods etc to use with 280zx/r31 struts in a 1200?
cheers jake
Posted on: 2007/7/12 11:00
Re: brake upgrade
From Geelong, Vic
id say the weight would be the same
mounting is the same also, use stanza stuff
just have to get a sheer load spacer for the steering arm so that the strut locates properly
Posted on: 2007/7/12 11:04
Re: brake upgrade
pigdog your a champion thanks!
Posted on: 2007/7/12 11:19
Re: brake upgrade
From Brissy
is there any hubs can i use to shorten the track width on my stanza struts???
it sticks out past the guards and i don't want to buy new rims..
also the 120y hub won't fit because the stub axle has a larger diameter???
Posted on: 2007/7/12 11:55
Re: brake upgrade
From Adelaide, Australia
Tappet, Late model 1200 ute or 120y (74 or 76+??) lower arms may do the trick, the stanza/sunny balljoint will bolt to the lower arm which should be the same length as a 1200 one.
You will have heaps of positive camber though, on my partners 1200 with stanza struts + stanza lower arms I have used 13" suzuki fwd rims which are super close to the strut and clear the guard no problems, stanza struts are way too much trouble to fit in a 1200 properly, and the brakes arent even that good.
Posted on: 2007/7/12 12:06
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: brake upgrade
From Brissy
they may even be 240k struts??
they have already been shortened and has a decent sized disc...
just the wheels stick out too far and i don't want to put in shorter lca"s as i want as much neg camber as i can get.....
surely there is a hub that will fit that brings the offset in???
Posted on: 2007/7/12 12:18
Re: brake upgrade
Well all dato's up to Z31, save the 1200 and early 120y use the same wheel bearing so you'll have to do some research, have fun!
Posted on: 2007/7/12 12:22
IPRA Build
« 1 (2) 3 »
