need help with holley as she idles @ 2000rpm
Not too shy to talk
From Brisbane QLD
just put my holley g180 on and went to fine tune it, she started fine once the fuel got there then reved up to 2 grand then sits there. to slow it down i have to push the linkage back a poofteenth then its fine till i let go, the cable is not tight, the linkage is not binding but she still wants to rev to 2 grand. i have checked the idle speed screw and it is not even touching the stop plate and disengaged the elec choke. any thoughts?
Posted on: 2003/3/23 2:01
Re: need help with holley as she idles @ 2000rpm
From Canberra, Australia
return sping?
So when you put you foot down it revs normally and then when you take you foot off it stops at 2000rpm? Adn the only way to make it go under 2K is to push the linkage back?
Is the cable sticking?
run your fingers down the cable just where it comes out of the covering thing(Can't think of the word??) run them up and down and if it prickles you then that might be what it is.
Otherise I would say return spring.
BUt then again, I don't have much of an idea...
Posted on: 2003/3/23 2:45
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Not too shy to talk
From Brisbane QLD
thanks but the cable is as loose as, cause i was tryin to eliminate all possabilities. i will try to muck around with the return spring and c if this makes a diff. i noticed that u have one too, no probs with it.
Posted on: 2003/3/23 2:51
I haven't had any real problems with mine. But carby dudes set mine up...
I stoppped using the stnadard 1200 throttle cable with mine cos it kept on snapping.
The one I have now is a little thicker.
Also with the standard throttle cable (I went through about 4) it would also start to fray and stick. Thats why I thought that might be the problem with yours.
Try WD40ing up the linkage. It might be stiff or something.
You haven't got chokes on it?
Sorry, I'm not too sure...
Posted on: 2003/3/23 3:39
From Christchurch New Zealand
i have the same problem but the engine rushes right up to 7 grand i dont think that the return spring on the pedal is strong enough so ill add one on the carbs
Posted on: 2003/3/23 4:06
"If your not living on the edge your taking up too much space" Rod Millen
From Melbourne, Australia
as far as i know all cars have em on the carb too
Posted on: 2003/3/23 9:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Not too shy to talk
From Brisbane QLD
i went and took the linkages of and wound up the return spring this has fixed the revs to normal but i will have to get a stiffer spring as it is a flimsy one and it is done up so much that it is restricting the full range of linkage cycle. i also took the choke blades off as i dont like chokes( never have, never will) just a bit of pedal and she's away
Posted on: 2003/3/24 0:24
From Toowoomba, australia
you could also check the mixture screw because my 32/36 (which is the same as a 180 holley) was doing the same thing and by playin with mixture and the stop screw for the secondary fixed her up sweet. she's for sale by the way
DAVE
Posted on: 2003/3/24 9:44
why go up and down when you can go round and round
