(1) 2 3 »
question about oil blockage. any ideas would be a great help.
From Adelaide, SA
i recently changed the head on my car and it seems oil is not coming up through the head. what could be causing this problem and how can i fix it. any ideas would help as i wil be pulling head off tomorrow.
Posted on: 2007/7/13 10:49
Re: question about oil blockage. any ideas would be a great help.
probably got a later or earlier head on the wrong block..... im not to sure plenty of the others blokes know....... maybe even try the search button or the wiki
Posted on: 2007/7/13 10:50
From Adelaide, SA
oh that makes sense is there anything i can do to make them suit.
Posted on: 2007/7/13 10:54
as far as i know you have to possibly drill a hole where the oil gallery from the block thats goes on an angle to a passage in the head..............but ive never done it before so i wouldnt take a drill straight away
Posted on: 2007/7/13 10:56
Posted on: 2007/7/13 10:58
Any A series head will fit & work on the late block. IE, 1974 & on with rear distributor.
Only A10 & 1200 head will work on these engines 'as is'. [front distributor]
Late heads can be used on A10 & 1200 engines if they are modified to allow oil to get to the rockers.
This is not a big deal & I have seen a crude system where a 1200 head gasket was placed on the head to determine the position of the oil feed hole in the block.
This was centerpunched & a very shallow hole was drilled. [about 1 to 1.5mm] then an angle grinder was used to grind a small trench across the gasket face to provide an oil passage froom this shallow hole to the nearest head bolt hole.
Crude as hell, but it worked. A very steady hand would be a prerequisite.
Personally, I would suggest a milling machine if this method is used.
Posted on: 2007/7/13 16:11
Love your Datsun.
Treat it well.
From PORTUGAL
One of the bolts in the head is DIFFERENT from the others ( small radius ) for allowing the oil to pass - are you sure it is on the right hole ???
Posted on: 2007/7/13 23:04
The Worst it Looks - Bigger The Challenge ...
You need both:
* the thinner Head Bolt in the middle right side
* Newer head on older engine: Need to drill the oil passage:
Newer head -- no oil passage:
Cylinder Head Oil Passage
Posted on: 2007/7/13 23:11
From Adelaide, SA
if i was to try this drilling hole method could i drill on an angle towards the head bolt and eliminate the need to put a channel
into gasket
also would bolt marked T go on the side were i am drilling this hole (left/spark plug side) or on other side (right side) as it says in manual.
Posted on: 2007/7/15 3:02
From Adelaide, Australia
Ahhh, that was your car matt at my workshop the other day....
Was gonna ask on here who's it was, i saw the datsun1200.com sticker....
What did you put on the head gasket? some silicone based silastic? Thats your problem there, i could see it all squishing out the side between the head and the block. You've blocked the hole.
looks good though....nice coupe
take care
Posted on: 2007/7/15 16:10
(1) 2 3 »
