Wiring electronic dizzy
From The garage, NZ
As i have no real knowledge of electronic dizzys apart from the real basics im asking here
i have an electronic distributor from an 86 c22 vanette (a15). Picture:
Where do the two little wires go from the dizzy?
I assume the blacks an earth ? maybe the other to the coil ?
Any help will be kindly accepted.
Cheers
Posted on: 2007/7/8 0:11
Re: Wiring electronic dizzy
From Burbank, CA
This must be a way late model one, all the ones i seen here had a black ignitor box on the side, but still 2 wires. i think both go to the coil and they are +/- so one is ground and one is +12...
but check, since i have a weird ignition setup.. I use the coil + as power to my ignition box, use a seperate ground and use the coil - as a trigger signal for the ignition box. my coil is run by the ignition box directly.
Posted on: 2007/7/8 0:35
|||\ 81 KPB310 /|||
From Perth WA
Yeh i would say they bot goto the coil. Logic would say that the blue one would be positive and black negitive. But these are the exact same wire colours as a E15 electronic dizzy and they are the opposite way around. black/white is pos and blue is neg.
Try wiring it up, if it doesnt fire, swap em!
Posted on: 2007/7/8 2:10
Chris...
From Burbank, CA
looks like you might want a fresh rotor too... Sure won't hurt...
it's interesting that that rotor has like the circular notches, all the ones i've seen here had a smooth radius.
Posted on: 2007/7/8 6:07
|||\ 81 KPB310 /|||
From The garage, NZ
yea i know, its shot
Anyone else have any confirmation?
positive to positive on coil and neg to neg on coil ??
Posted on: 2007/7/8 10:39
From Adelaide, SA
Did you get this sorted Cheater?
I picked up an E15 dizzy the other day and it is the same.
The blue wire goes to the coil minus (-) and the black wire with the white stripe goes to the dizzy plus (+)
Posted on: 2007/7/17 5:30
From Christchurch NZ
If you cock up the polarity, chances are you'll root it. Post a pic of the underside of the dizzy if it's not in the motor already. My NOS electronic dizzy has a clip on cap.
Posted on: 2007/7/17 10:14
Forced Induction!
Quite a regular
From Adelaide, Australia
E16 dizzy running on A12
Posted on: 2007/7/17 10:24
Quite a regular
From sunshine coast QLD
Blue goes to negative side of coil, Black/white goes to positive side of coil. Make sure you change the coil to suit electronic, wrong coil can also damage dizzy.
Posted on: 2007/7/17 11:15
Talasas, are they your fingernails? How do you keep them so long and clean?
Posted on: 2007/7/17 11:46
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
