« 1 (2) 3 4 5 6 »
Re: 9 inch diff quote wat u think??
From Geelong, Vic
yes very hard to get LSDs for r31s....only almost every falcon or commodore LSD will fit and work (as long as its 28 spline and 3.08-4.11 ratio) falcon ones are apparently the ones to use
id go a 9 inch over a patrol diff, would weigh about the same as patrol diffs are huge, and just coz the 9 inch is a more common conversion.... who cares if its not nissan really
and probably a hilux one over the 9 inch as they would weigh slightly less????
EDIT: wow didnt know patrol diffs were that f'ing big
Posted on: 2007/7/18 4:03
From perth airport
yea i hate paying for something that will fuk up later ( r31lsd ) i would rather pull around a 9 inch that weighs say 30kg more ?? and know i neva have to pull it out / fix again
Posted on: 2007/7/18 4:11
From Geelong, Vic
why would the r31 diff fuk up ?
30kg more is almost another half of the r31 diff....its a lot of weight
and are you saying that a 9 inch will never ever make another noise or vibration.....well i guess if you payed $2500 for a diff that you still had to put in your car, you would want it to live for ever
Posted on: 2007/7/18 4:14
From Townsville, Nth Qld
Doesn
Posted on: 2007/7/18 4:28
Cheers
Davo
From perth airport
pigdog wat would u think would last longer
a r31 lsd diff or a 9 inch diff ??
and to buy a r31 diff, shortened and the mounts welded on and the axels shorten and rebuild the diff would cost how much ?? maybe $1800
if it is 30kg thats not that much weigh some people have sterio gear that weighs that much
Posted on: 2007/7/18 4:30
hey perthute, pm Joshh... he just had R31 LSD put in n has been drivin it round 4 lil while now... he loves it... mite b worth a chat..
Posted on: 2007/7/18 4:33
Cheers
Davo
From perth airport
maybe its overkill but ihave broken too many diffs
Posted on: 2007/7/18 4:34
How u killin ur diff's?
Posted on: 2007/7/18 4:37
Cheers
Davo
From perth airport
davo im not getting it till i sell my 180sx and i have a big shopping list for the datto so it might be a month away so ill see hows yous goes . did you get the diff rebuild ??
Posted on: 2007/7/18 4:41
From Gold Coast
Theres a blue 1200 ute up here running 10
sec and hitting the back bumper and he only has a skyline diff and is raced all the time.
So unless you plan on a super quick car you dont need any bigger
Posted on: 2007/7/18 4:50
« 1 (2) 3 4 5 6 »
