« 1 (2)
Re: Is anyone running a 13/16 master cyl w/out a booster?
From Perth
I use a 13/16 Sunny master in my 1000 kits
No booster
Up from an 11/16 single (or tandem on a coupe)
It suits it well
I just have to make pushrods to suit the masters
The 11/16 master is captive (rod stays in master) wheras the Sunny used to sit on a booster
So I make a special rod to use the Sunny master unboosted
You may need to do this also depending on your original master
If you try to use the original captive rod in the booster master you may have issues
Posted on: 2007/7/31 4:45
From Christchurch NZ
Cheers 1000. I shouldn't have too much trouble sorting ot the push rod.
Posted on: 2007/8/1 1:16
Forced Induction!
From Adelaide
Can any one tell me what size masters 240k's run (i think 7/8). I got one at U-pull it because i'm upgrading to r31 strut and 4 spot z32 calipers. I grabed the booter as well. Will this suit my app?
Posted on: 2007/8/2 12:13
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Geelong, Vic
i was running an unboostered 7/8th(240k)....got over it and added a booster in as part of the latest brake upgrade
alot better for the street now that it has a booster, but i think i'll soon be upgrading to a 15/16th to get rid of some pedal travel. got 300zx brakes all round and they run a 1 inch or 17/16 from factory so i think the 7/8th is a bit small
Posted on: 2007/8/2 23:42
From Adelaide
The 300zx boosters are massive though aren't they (will they fit with a CA). What booster will you run with the 1" or 17/16 master. I'm only going to be running std r31 fronts to start with, the 7/8 master will be fine for them wont it?
Posted on: 2007/8/3 15:27
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From Geelong, Vic
you can use modify one of the small can boosters to use the later nissan masters, yet to get a late nissan master to test though
but i think i'll just go for a 280zx 15/16th as it will bolt straight up
7/8th should be more than enough for r31 brakes
Posted on: 2007/8/3 19:54
From Adelaide
Cheers, full of all the good info aren't you.
Posted on: 2007/8/3 21:10
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
From South Africa
ok guys this is some years later but i need some help , i have a 1200 delux and the two nose bottle system pretty standard and have changed the brake cylinder master kit and the brakes are still as hard as hell , can you guys advise what to do or change ?
Posted on: 2010/10/29 14:18
Are you still running the 11/16 master cylinder?
I never did change my M/C in the end. Wound up going S13s on the front, and although it does have a whisker more travel than is ideal, the pedal has excellent feel and control.
Posted on: 2010/10/29 22:09
Forced Induction!
« 1 (2)
