(1) 2 3 »
express intrest : adj. strut tops
From Melbourne, Australia
im thinking of designing and making some adjustable strut tops
well sort of
i was gonna sit down with my mechanic and draw up a design for some
then take the design to work and try to con the machinists into making up the bits on the CNC machines and all the other special tools they have
plan is to use aircraft style alloy, using two appropriately shaped plates to sandwhich the bearing, then have adjustment for camber and castor
im not sure if this is gonna work or if i can get the machinists at work to make even one or more sets but im gonna give it a shot and was wondering if people would be interested if i could get a few sets made up
i would have no idea of price but the idea is to be a fair bit cheaper than the ones ive seen for sale (over $500 for the pair) otherwise i wont bother
Posted on: 2003/3/24 10:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: express intrest : adj. strut tops
Yeah its a good idea... The alloy you are thinking of is 6061 T6, which is the highest grade automotive round. 7071 T6 is the flat plate you need.
I've designed some up already, and was going to make them soon.
Also make sure you use reasonably good rose joints, as they make all the difference.
If you want to check out my design let me know, and l'll capture some jpegs of the drawings.
If you can get them machined free, or really cheap then l'll be very interested!!
Posted on: 2003/3/24 10:13
From Portland, Vic
It just so happens that me and a mate are in the process of fixing up a cnc machine, which also includes a lathe.....drool!
So many things to make! Anyway, if you have no luck with the guys at work etc, we may be able to have a bit of a go for you.
Leigh
Posted on: 2003/3/25 4:52
- 1985 Datsun 1200 Ute - S5 13b Turbo
cool, id love to see the pics
and cool sounds very good
Posted on: 2003/3/25 8:20
1200 Coupe Rallycar
From Sydney NSW
You can buy adjustable strut tops from k-mac suspension aprrox $340
Posted on: 2003/3/25 8:55
thats not a bad price actually, does it adjust camber and castor? do you know?
Posted on: 2003/3/25 9:02
1200 Coupe Rallycar
Not too shy to talk
noltech make them to
Posted on: 2003/3/25 10:55
From Sydney
i used some of these for 2 years....personally i didnt like them.....there are much better ones out there, but they cost a few extra dollars
Posted on: 2003/3/27 0:36
From Mudgee NSW Australia
The noltech ones are $500 and look lots better made than the Kmac I have seen many types between $300-$700 depending on name brand and adjustability. I would pay upto $400 for a top quality alloy set with camber and caster adjustability. So count me in if you can do a set for under that.
Cheers Andrew
Posted on: 2003/3/27 10:53
From Western Sydney
ditto
Posted on: 2003/3/27 12:17
www.datnet.org
(1) 2 3 »
