Front Suspension Upgrade Help
Quite a regular
From Perth, West Australia
Hey all DattoMANIA people. Need some advice. Am thinking of up-grading front suspension, which is the best way to go? Don't want to go excessive in unsprung weight but want better stopping power as well. Have a hot a14 and H165 rear. Was thinking of coilovers plus maybe sunny brakes setup modded to it. While im on the subject what's the best rear setup leaf spring wise and whats the best shocks to use? Anyone attempted 3 or 4 way link setup, is that a lighter setup than standard? Any help is appreciated. Cheers!
Posted on: 2007/7/22 18:24
Re: Front Suspension Upgrade Help
Quite a regular
anyone able to help and give me some advice on this setup???
Posted on: 2007/8/3 4:52
cut and shortened 120y struts with coil over setup on it, jeff taylor (??) silvia brake setup for the front ... probably the lightest option ....
or stanza/200b/240k struts cut to length and coil overed with 253mm slotted rotors and sumitomo twin spot calipers ... probably one of the cheaper options ...
rear leaves - supposedly the man for them is john taylor (??) used to be in penrith, sydney pedders, has a magical leaf combination for circuit/street ... maybe one for rally aswell ??
or the search button over there on the left will give you plenty other options and even more info on the setups i mentioned above
Posted on: 2007/8/3 5:01
oh yeah ... for great qulty coil over kits and camber tops have a look thru SSSUTE's photo album or have a look at the maddat web site
Posted on: 2007/8/3 5:03
Quite a regular
Cheers Boofhead. Just out of curiosity is the sunny/120Y same setup for clearance of wheels as opposed to standard 1200?
Posted on: 2007/8/3 5:16
from memory yep .. but both have pretty ordinary brakes as standard
Posted on: 2007/8/3 5:20
For an overview, see wiki - Suspension upgrades
Move to an H150 rear for *much* lighter weight and can withstand the force of a modified A14. The B210/B310 have the same rear brakes as B110, so no gain there.
Best leaf spring setup
My opinion is the original specification rear shocks are best -- they control the rear much better than gas shocks. However I haven't tried any of the adjustable shock absorbers, so maybe adjustable Konis might be best?
Shock part numbers
Posted on: 2007/8/3 10:34
From Burbank, CA
someone has a source for the koni adjustable rear dampers? I didn't think they still had any of them left.
Posted on: 2007/8/3 11:06
|||\ 81 KPB310 /|||
