DIFFS
From melbourne
Hello ,
could anyone tell me if a 1200 ute diff centre will fit straight into a 1200 coupe diff housing ....... also are the axles the same on ute and coupe ...... does stanza also fit and are axles the same ..... are they all h165
thanks
joe
Posted on: 2007/8/14 16:09
Re: DIFFS
Yes they will. Diff center and axles are the same between Coupe/Sedan/Wagon and 1971-1973 ute. Newer utes use the bigger H165 rear and so will not interchange with the B110 housings.
Posted on: 2007/8/14 16:15
Re: DIFFS
From NSW South Coast
As far as I know 1200 Coupe, Sedan, wagon and all 1000 are all H145, All 1200 uts are H165, Stanza are H165 with longer axles. Coupe axles won't fit a H165 centre
Posted on: 2007/8/14 16:22
Re: DIFFS
From gold coast QLD.
I may be wrong,someone correct me if i am,but i am yet to see an Australian delivered 1200 ute with anything but an H165 installed in the back,and no they won't interchange bits with the sedan or coupe or wagon.
Posted on: 2007/8/14 20:02
Re: DIFFS
From melbourne
my understanding is that all utes have h165 but what do coupes have h145 or h165 ?
Posted on: 2007/8/14 21:34
Re: DIFFS
From southern sydney "the shire"
coupes have h145's. it wouldnt be to hard to change the rear end though i cant imagine. it will be stronger and widen the track with the h165
Posted on: 2007/8/14 21:41
Re: DIFFS
From melbourne
thanks champ
Posted on: 2007/8/14 21:44
Re: DIFFS
From Geelong, Vic
a ute h165 will keep the track width the same
Posted on: 2007/8/14 22:16
Re: DIFFS
Quite a regular
From Melbourne,Victoria,Australia
Looks like thr diff in the 1000 is a H165 mate...
Posted on: 2007/8/14 22:33
Re: DIFFS
From Adelaide, Australia
1000 diffs are H145, like pigdog said the ute diff keeps the same track. KE55 Corolla bw diffs widen the track by about 2inches overall.
Posted on: 2007/8/14 22:35
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
