radiator just broke
From canbetown nsw
can anyone tell a good replacement for the one in my 69 1000 ute is there any from other cars that fit stright in plz help
and would a exhurst manifold off a 1200 fit on to my 1000 engine
Posted on: 2007/8/15 16:57
Re: radiator just broke
From Brisvegas, oz
yeah the exhaust manifold of any a series should fit. as for the radiator im pretty sure any other radiator is going to need a little modifying
Posted on: 2007/8/15 19:57
www.camerasplus.com.au
From South Africa, Bloemfontein
How badly is it damaged.
Just get it recored.
While at it put in a heavy duty core for that extra hot days.
Posted on: 2007/8/15 20:48
1977 Datsun 1200GX
From canbetown nsw
the bottom piece were the hose goas on broke while pulling motor out to do clutch
Posted on: 2007/8/15 21:13
From Perth WA
You dont need to pull a engine out to do a clucth??? Just the box'll do!
I used a Hyundai Excel X3 rad in my 1000. You have to make brakets up and modify hoses but it fits in!
Take it to a radiator shop and see what they can do with the old one for you.
Posted on: 2007/8/15 22:51
Chris...
If any would, the 1971-1973 1200 would. Newer engines used a 3-bolt exhaust manifold, while older ones used a 2-bolt exhaust manifold. I mean where the exhaust pipe bolts to the manifold.
Posted on: 2007/8/16 0:25
Actually, removing the engine for a clutch change could well be a simpler way to do it if one can't get enough room to work under the car.
1000 & 1200 engines are quite easy to remove & working over the front of the car is a lot less drama that working under it.
I suggest that you take the radiator to a radiator specialist to get a verdict on it. He may just be able to repair it, unless you have ripped the bottom tank to shreds.
If it is fixable, then you might as well get him to pop the top tank off & rod, or replace the core [as necessary] to make sure it's nice & clean when it goes back in.
Posted on: 2007/8/16 0:48
Love your Datsun.
Treat it well.
From Bris Ozzztraileeaarr
Mate if the bottom pipe has come off it,s a simple fix don,t stress, shouldn,t cost any more than $20 at the nearest radiator shop {it,s a 5 min solder up fix!} But as other guy,s have said get em to clean it while it,s out.
Posted on: 2007/8/16 6:27
From canbetown nsw
thx for all ur help im very new to the datto seen must say very good group of ppl for giveing advice
Posted on: 2007/8/16 11:07
From Perth WA
I have a gemini radiator in a 1000 very simpl;e swap. but gettimg your old one recored heavy duty would be better option.
Posted on: 2007/8/16 11:22
