(1) 2 3 4 »
Disk Brakes.
Soon I'll be putting a ca18det in my 1200 ute, I want disk brakes, but which will be the best option
Posted on: 2003/3/31 12:28
Re: Disk Brakes.
From Melbourne, Australia
stanza struts!!!!
Posted on: 2003/3/31 12:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Disk Brakes.
i decided ill be nice and tell you about them and how to put em in
this is off my own site
brake upgrades!
ive discovered a problem with this though, if you use the 1200 springs the ride height is slightly raised and positive camber (read: hanus understeer) results, you need to use lowered stanza springs, id go with king springs as opposed to cutting stanza ones. doing this you will have negative camber (read: awesome turn-in)
Posted on: 2003/3/31 12:38
1200 Coupe Rallycar
Re: Disk Brakes.
From Brisbane
rallycar on your site you said you werent sure that 14x6 would get on to the stanza struts?
i want stanza struts but my mags are 14x6 i shouldnt have a problem?
(p.s the conversion seems pretty simple )
Posted on: 2003/3/31 14:41
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: Disk Brakes.
From Newscastle, Australia
Hey Rallycar, do you also suggest the Stanza discs and calipers too? I want to race a sedan/coupe in CAMS club car 3J and want something thats going to withstand repeated stomps in the pedal coming down from speeds such as 200kph at Eastern Creek.
Do you suggest slotting the rotors, twin spot calipers? Something that doesnt give pad fade, boil the brake fluid etc etc.
Posted on: 2003/4/1 23:13
Re: Disk Brakes.
From nsw,AUSTRALIA
if u wana use stanza struts and stuff but the disks and that arnt good enough go to dba and get custom made ones my dad got some we have never ever smelt the brakes since we did that and my dad cars is 2 and 1/2 tonne and we have the camper trailer on the back witch in 500kg and there all filled to the max so about 3 or more tonne and we go donw kangaroo valley and that is super steap and long if no one knows of it well its not super steap but its still steaps and wyndy
Posted on: 2003/4/2 8:14
A14+1200 ute=dirty pants
Re: Disk Brakes.
yeah 14x6 will be fine, i need to update my site with my more current knowledge
the disc and calipers (girlock) are good
but for a cicuit car id toss em, on the same page im pretty sure it has a conversion for hi-lux 4 spot calipers, this is what i have on my road car and they are f'n unreal
you use pintara VENTED discs, these need some machining to fit, both to open the centre and to thin the disc if required
and hi-lux calipers which also may need some machining of the body of the caliper for clearance
i did not install these my bro-in-law did, and if you have more questions about the install (if the info isnt on my site, dont really remember), just ask and ill find out, no probs
and something else thats on my site id recomend is the bluebird disc over drums for the rear if you have h160 or h190 diff (also recommended diffs to use )
and a sunny booster
Posted on: 2003/4/2 11:05
1200 Coupe Rallycar
Re: Disk Brakes.
just thinking....
for a circuit car actually, it would be good to do 240k struts
biggest prob with these is you need to change spring purch to fit smaller springs, but when doing this you mount the new perch on thread and make the struts adjustable ride height
some 240k struts have twin spot calipers already but id still be tempted to go hi-lux with vented discs (cant remember if 240k is vented???)
side note: both the hilux brakes and the bluey disc overs will not fit under 13" rims, 14" is minimum
Posted on: 2003/4/2 11:09
1200 Coupe Rallycar
Re: Disk Brakes.
From Perth
datrats does his conversions using 240 brakes (vented disc) on 200B struts
Posted on: 2003/4/2 13:26
Re: Disk Brakes.
pretty sure 200b struts are extremly similar if not the same as stanza struts, but dont quote me
i figure if ya gonna change the discs you may aswell do it properly
but hey good suggestion if it is a straight bolt up
Posted on: 2003/4/2 14:54
1200 Coupe Rallycar
(1) 2 3 4 »
