Datsun 1200 wirring questions...
on the passendger side
there is a wite with red stripe wire is this the starter motor wire???
on driver side there are 3 green wires near fire wall?????
all the rest go to battery im guessing???
And where is the original wirring for wiper motor???
im sure ill have more on this 1???
but that will get me started
any help
thanks
Posted on: 2007/8/18 20:35
Re: Datsun 1200 wirring questions...
From Mandurah, Western Australia
3 green wires go to the horn relay. I think.
Wires for wiper start at drivers side of engine bay near fire wall. A lead about 1m long runs along firewall to the wiper motor and plugs into loom at right side of engine bay.
White with red??? Cant recal would have to get manual out for this one.
Have you got a wire diagram of a 1200. Makes things heaps easier.
If no you may find one on the net or a manual at the local library. Or maybe someone in your area could organise photocopy.
Let me know how you go or if need copy of wire diagram.
Posted on: 2007/8/18 20:46
still stuck on wirring
i might post pics and label the wires i dontno
Posted on: 2007/8/19 20:24
From Adelaide, Australia
What country?
Posted on: 2007/8/19 20:29
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Australia 70 model
Posted on: 2007/8/19 20:33
From Brissy
the white red is for ur alternator...
the three wires, 2 greens and one black is for ur horn relay.. the black should be earthed
the starter motor wire will be closer to the firewall end and is black/red i think..
the wipermotor has it's own plug that is also nearest the firewall on the engine loom....
Posted on: 2007/8/20 7:38
white with red stripe=alternator=passenger strut
3wires,2green,1black=horn relay=close to firewall and driver strut
?????=horn
Starter motor=black/red=close to firewall
is this correct so far???
anything else or more details???
cheers
Posted on: 2007/8/20 11:31
From Quairading, Western Australia
don't know about an early 120Y or 1200 wiring loom
but on a late (March '77) 120Y aussie 120Y the wiper motor wires and anti deseling switch (yellow wire) are in a 1 metre lead closest to the firewall - closest to the two rectangular pugs under the dashboard
then the headlight relay is on a short lead nearby
the horn wires are near the plugs for the indcators and parklights/under bumper indicators
I think they are green - 120Y's have 2 horn wires as they have 2 horns
Posted on: 2007/8/25 2:38
