(1) 2 3 »
1000 diff width
From Geelong, Vic
simple question really, how wide is a 1000 diff from drum to drum?
wiki didnt have anything that i could see that was helpful
Posted on: 2007/8/21 6:40
Re: 1000 diff width
From gold coast QLD.
1240mm drum to drum give or take 2mm
Posted on: 2007/8/21 6:48
Re: 1000 diff width
From Geelong, Vic
damn they are small
but should make it easy to shorten diffs to that size
next, distance between the leaf mounts?
Posted on: 2007/8/21 6:59
Re: 1000 diff width
910mm centre to centre,leaf mount plate 65mm wide.Cheers
Posted on: 2007/8/21 7:40
Re: 1000 diff width
From Newcastle (NSW)
hehe! whats the plan ??
Posted on: 2007/8/21 11:29
Racecar spelled backwards is racecar!
Re: 1000 diff width
From Geelong, Vic
h165s(bluebird) are pretty easy to shorten these days, same with the 120y sized BWs from 200bs and corronas and the axles should be long enough to allow for each side to be cut and resplined
would be a good open or locked diff for a 1000 that had a bit more power than average
Posted on: 2007/8/21 11:34
Re: 1000 diff width
From Perth
I have average power
I'm interested to see how this works out
Shame I sold my H165
Posted on: 2007/8/21 11:55
Re: 1000 diff width
From Geelong, Vic
ive already done it to a h145....but i made it really really short just for the hell of it
and when i had a bluebird h165 i put my ute diff axles next to the bluebird ones and there was enough full width axle to cut the bluebird ones down to make ute axles....so shorter 1000 axles shouldnt be a problem
so say $110 an axle(cut and resplined), $50-100 for me cutting down and rewelding the housing
now i just need lots of bluebird or corrona diffs so i can create an army of tough 1000 diffs
measured a 200b diff, might just get away with using them, hopefully some of the axles have less of an under sized bit than others
maybe i should get a 1000
Posted on: 2007/8/21 17:51
Re: 1000 diff width
From Coondle, WA Australia
hmm sounds intresting, keep us all posted....
Posted on: 2007/8/23 5:57
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: 1000 diff width
From Geelong, Vic
well if people start donating bluebird diffs, boofhead im looking at you
i'll probably cut down a BW on the weekend if i get bored
Posted on: 2007/8/23 12:40
(1) 2 3 »
