are there any axles that are about 135cm across?
From Invercargill, new zealand
im putting a datsun engine in a morris minor and i need to know if there are any datsun axles out there which have a drum to drum width of 135-140cm. also must have the 4x114.3 stud pattern. doesnt have to be a datsun axle.
cheers
Posted on: 2007/8/30 7:33
Re: are there any axles that are about 135cm across?
KE55 corrola are pretty much spot on 135cm face to face and correct stud pattern.
Posted on: 2007/8/30 9:04
From Geelong, Vic
corrona borg warner diffs (if your in australia) are pretty much spot on 140cm across
Posted on: 2007/8/30 11:31
thanks for that, ive found a diff off a kp60 and im just getting the seller to measure it up and the stud pattern. does anyone know the ratio of a kp60 diff?
cheers
Posted on: 2007/8/30 12:13
does anyone know the width of a kp60 rear axle? ive found out its 4x114.3 which is great but i havnt been able to contact the seller to ask the width. cheers
Posted on: 2007/8/31 10:26
