« 1 (2) 3 »
Re: Engineers
NO diff
u pay for engineer to turn up and do paper work.
ange...
does that mean any engine upgrade will only require front brake upgrade???
also
if 1200 ute come out with drum front will any disc brake front will be a upgrade???
the engineer will say its safelt put in and blueslip do a brake test
cant see any problem with any disc brake front on a drum front car
Posted on: 2007/9/3 9:33
Re: Engineers
From Canberra
you bought the white one off her for $5500?
If so nice buy!
But wouldnt it be better putting the good gear into a better shell and getting that engineered? Probably cheaper than a resto.
Those prices seem damn good I think I'd be up for $1200+ to get mine done, and it would have to go to sydney for testing
Posted on: 2007/9/3 9:51
Re: Engineers
From Geelong, Vic
so you would be after a real BW diff to put under the 120y now jordan.....ive got a spare that needs to be turned into money
Posted on: 2007/9/3 10:30
Re: Engineers
From Melbourne AUS
its not a matter of just having a brake upgrade. its gotta pass the brake tests.
for my engineering test, they did 10 consecutive stops from 60kph (to heat up the brakes i presume) then 2 stops from 100kph. And measure the braking force with some sort of g meter.
mine was engineered with stanza discs and girlick calipers. no booster. it passed easily.
engineering a conversion is very daunting but it doesnt need to be.
i got the go ahead from my engineer before i started my conversion, that way he was expecting me. i consulted him throughout the conversion with questions and queries, that way all the work was done to his requirement. So he basically knew what was coming in before he had even seen it. And it passed first go.
i highly reccomend doing it that way, worked for me and if i ever do another conversion ill be doing it the same way again.
im an electrician by trade who knew not much more than how to service a car before i fell in love with datto's. if i can do it. so can you.
good luck.
Posted on: 2007/9/3 11:54
1973 B110 A12
Re: Engineers
From Wallan, Vic, Aus
haha, i dont know about the white one from"her"? I got it from a guy in adelaide called rob, a young bloke, managed to get it for $4500 instead if $5500 because its gonna need a lot of work, and yeah i was planning on getting a new body as its absolutly trashed haha. So pigdog, whats so good about that diff? Is it a tough one? cos im gonna need one.
Posted on: 2007/9/3 13:48
Re: Engineers
I had a look under the car this arvo and it has a Borg Warner 120y Diff, so sorry pigdog, unless you have another ute diff or somthing stronger?
Posted on: 2007/9/4 7:36
Re: Engineers
From Geelong, Vic
hahaha 120y BW diff, no the one im talking about would be an r31 diff....you know like a v8 commodore diff
its the one i upgraded to from the ute diff
Posted on: 2007/9/4 7:40
Re: Engineers
From Canberra
woops sorry that was supposed to say here (datsun1200.com) not her...
Posted on: 2007/9/4 8:26
Re: Engineers
ah right, well that makes sense then, but yes thats the same car your talking about i think. It looks better in those photos he had up. I can tell you the flared guards are bad, done with vice grips lol. Pigdog, what would I need to make that diff fit a 120y, cos if its a V8 one, then I might actually be interested in buying it.
Posted on: 2007/9/4 13:47
Re: Engineers
From Geelong, Vic
yeah r31 28 spline BW, same as most people run behind there CAs
to fit the 120y, well it will go straight in....but
you need to find a complete R31 diff to use the axles and centre and stuff out of as i need all the insides for my new diff
but will still work out alot cheaper than getting one cut down and stuff
Posted on: 2007/9/4 14:02
« 1 (2) 3 »
