some ideas on my 1000 ute
From canbetown nsw
the wife has given me the ok to start doing up my 1000 ute i would like to change to a feul injected motor may turbo or supercharged 1.6l
does any one know wot would be the best choice i have a ok budget to start getting parts together and bits and pices
does anyone make any sort of conversion kit for this little soon to be best would a 4age or some sort of 20v motor be ok anyhelp would be a god send
wot would the best diff i should have cut down
Posted on: 2007/9/3 7:27
Re: some ideas on my 1000 ute
From Coondle, WA Australia
you could go with a a15 and turbo. its easyish to install, and plenty of power to be had from the a series.
the 1k doesent seem to be too popular with other motors for licensing reasons and that the engine basy is a little low.
There are heaps of people on this site doing conversions into 1k,so keep you eyes out for threads about em.
also, do a seach with the seach bar to the left, there is heaps of info in the database.
good luck
Posted on: 2007/9/3 11:33
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From canbetown nsw
wot sort of power can be had from a a15 turbo Quote:
good luck
Posted on: 2007/9/3 23:19
The answer to that is
How long is a piece of string??
how much do you want to spend?
Where are you located? since that has a bearing on what you can cant get.
When my 15et is running, ill let you know what a reasonable 15 can achieve.
Posted on: 2007/9/4 12:27
From Perth WA
Topgear got what? near on 100rwkw from a A12 carby turbo? Internally standard too. only 10psi
Posted on: 2007/9/4 12:39
Chris...
From canbetown nsw
i live in sydney is it possable to get about 250 hp from a15t or would i be better off selling the 1000 and buying 1600 for 2l turbo
Posted on: 2007/9/5 0:01
From Canberra
If you've got the coin get an ae101 4agze, put a blacktop 20V head and TBs on with a metal headgasket, and a nice GT30. You'll need a supra gearbox to go with it. 250+rwkw is not out of the question for such a setup
Posted on: 2007/9/5 0:25
Highly unlikely. An extremely worked, welded & modified A-series head is only good for 225 hp, at least that's the highest figure I recall being reported.
You're better off with a turboed 1.6 liter in a 1000 than a 2 liter turbo in a 1600. The 1600 weighs more than 25% more than the 1000, so the little guy will have the power/weight advantage. Plus you have this community ...
Posted on: 2007/9/5 5:29
