question A series EFI
From Inner west nsw CAMDEN
hey all question about a series efi what did u use and how did u make it work?
Posted on: 2007/8/31 13:57
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
Re: question A series EFI
From Victoria
Jenvey quads, Wolf3D, Commodore HP fuel pump, surge tank. Easy
Posted on: 2007/8/31 14:01
From Coondle, WA Australia
These Jevney quads you speak of, what are they?
Edit : i found their web page at
jenvy
The plan for mine was a custom manifold, with a single throttle body. similar to a factory setup. The throttle body at 90' to the runners and injectors. This would also give the best setup for intercooling.
If you went multi TB setup then you would need some sort of plenum before the TBs to allow for a single connection point to come from the intercooler. With that in mind, intercooled setups would have to be single TB setups, but on the other hand a multi setup would look awsome!!!
From what I have read, the performace gain from multi tb setups arnt significant, and more to do with throttle response than overall HP gain
Posted on: 2007/8/31 14:49
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Victoria
The jenvey quads are webber pattern so they will bolt onto a webber manifold. You could build a plenum chamber and still have your intercooler. Yes they are much better for throttle response, I supose it depends on your application. If your racing ITB's are definatley the go.
Posted on: 2007/9/1 1:26
To get an overview on the topic, see wiki - EFI
Posted on: 2007/9/1 3:31
ok basically standard a14 efi looks like C*** lol
so my plan is twin webber sidedraught with custom plenum single throttle body an mpfi
maybe microtech still deciding
fuel system can run an sr20 so it dont worry me motor will handle around 20psi maybe more (well probably more hahaha)
front mount i still want to use and i might be decking it out making it lighter inside while retaingin granny spec appearance
what do you's think?
Posted on: 2007/9/3 12:29
FAT 120Y SR20de-NOS
I think it will look GREAT! And that it will cost you about $3,500.
Posted on: 2007/9/3 17:02
nah not that much maybe half if that
hit a stump though the twin sidedraught manifold is too long so have to compensate with using factory manifold and work a way around it
Posted on: 2007/9/5 13:44
FAT 120Y SR20de-NOS
From San Jose, California
Megasquirt is the answer to all of your problems. I've injected a car with it for only $250 using boneyard parts.
Posted on: 2007/9/5 15:25
-Daniel
I have been tempted to look at a megasquirt, but that requires the ability to do electronic stuff, and thats not for everyone, let alone someone like me who is not that flash with the solder.
Posted on: 2007/9/5 17:00
