« 1 (2)
Re: twin charged
From Toowoomba, Australia
that sorts that bit out and how does a hobbs switch work the next problem would be the one i mentioned earlyer is when the sc is boosting it would be getting lost through the turbo if you didnt have some sort of valve setup on a hobbs switch as well or is there some other way around this
Posted on: 2007/9/13 10:39
The substitute for cubic inches is forced induction....
wanted fender mounted mirrors 4 120y
& 120y hubcaps
120y 2dr every day driver
120y 2dr project
Re: twin charged
From Canberra
I believe the S/C would be after the turbo, S/C has a bypass valve so that when it switches off the boost from the turbo doesnt go through the S/C it goes past it into the engine.
I guess this would mean before the turbo spools up the S/C would be sucking through the turbo.
I think a properly sized modern turbo would be a better idea
Posted on: 2007/9/13 10:52
Re: twin charged
i see now i was also thought of a twin turbo setup with a small turbo (charade) or some thing that would be on boost at about 1000rpm and a bigger turbo that would be on boost at 3000 except i would like to bypass the small turbo while the big hair dryers running so i dont f**k the small one to quick and that could be a big task which one would have more potential
Posted on: 2007/9/13 11:09
& 120y hubcaps
120y 2dr project
Re: twin charged
ive done a few twin charged suzuki gti
broke traction to 4th gear
had to run 4 extra injectors
i still have this same setup for a gti
complete motor forgeez manifolds its complete
if any1 intrested pm me.......
planed to put in a cappucino convertible
but found hard to find rwd box
my opinion
get a engine that you can fit good
pistons
strong box
computer(with maps for engine)
because you run into problems later on
Posted on: 2007/9/13 12:20
Re: twin charged
demo would you be able post some pic please and how did you have your setup running
Posted on: 2007/9/13 12:32
& 120y hubcaps
120y 2dr project
Re: twin charged
its in pieces
but ill try chase some pics up as it was a mates brothers car i did it to last
but since sold it
he should still have pics ill find out
cant imagine it being clear pic in a fwd
u wont see much
Posted on: 2007/9/14 2:48
Re: twin charged
how did you run your setup? if the engines in peices would you sell it seperate to the engine or not
Posted on: 2007/9/15 5:11
& 120y hubcaps
120y 2dr project
« 1 (2)
