a12 safe reving
From melbourne
just wondering what it is safe to rev a stock a12 to as mine vibrates at about 5000 is that nornal and what do i do to get it to rev out further
Posted on: 2007/9/30 2:42
Re: a12 safe reving
A12 is designed to rev to 6,000 rpm.
Posted on: 2007/9/30 2:54
Re: a12 safe reving
From south australia
first thing would be an electronic dizzy then cam and valv springs some porting of the head and valve work and if that dosent work balence the crank and flywheel
Posted on: 2007/9/30 7:24
Re: a12 safe reving
None of that is needed "normally".
Normally an A12 will rev to 6000 rpm without any unusual vibration.
Posted on: 2007/9/30 7:33
Re: a12 safe reving
yes not for 6000rpm but he asked how to get it reving faster so i am talking 7 to 8000rpm
Posted on: 2007/9/30 7:38
Re: a12 safe reving
From melbourne
thanks man i have 7k valve springs but dont know what sort of cam to get or where to get one i dont know what all the lift and stuff means could you recommend a decent upgrade one
Posted on: 2007/9/30 7:41
1200 sedan a15 powered
Re: a12 safe reving
From Geelong, Vic
so it can rev safely a simple balance job would be a good step....and shouldnt be a last step
Posted on: 2007/9/30 11:39
Re: a12 safe reving
It depends on what you call 'vibrate' If it is clearly a bad shake, then there is something wrong, something's out of balance.
The stock, short stroke A series engines [A10, 1200, A12, A12A & A13] will rev to about 6,000 without any bad vibrations as this is the factory redline on the tach.
If it shakes bad, then first you need to identify the cause & rectify it as more revs will just mean more vibration.
Posted on: 2007/9/30 12:41
Love your Datsun.
Treat it well.
Re: a12 safe reving
From melbourne
alright thanks guys ill give it a shot
Posted on: 2007/10/1 1:10
Re: a12 safe reving
From sydney
You need to find out why its vibrating and fix it before you go doing all that other "hot up" stuff.
Posted on: 2007/10/1 1:16
