fitting 15s on front of 120y...need advice
Not too shy to talk
From Brisbane, QLD, AUS
i got trx 15s on the back already but having trouble with the front. I'm choosing between using spacers and flaring guards or puting stanza struts which involves mukin around....
any advice be helpful.........if anyone has had this done in brisbane, I would apprecciate if you could tell me where....as I dont too many places in brizzie....thanx
Posted on: 2003/4/20 3:24
u ask me why
I say why not
Re: fitting 15s on front of 120y...need advice
Any pics?
cheers.
Posted on: 2003/4/20 7:37
From brisbane
Gday mate, there is a suspension and brakes place next near the end of the service road at sprigwood. If you come down moss st and turn left, it is the 2nd last shop on the corner, next to the RubberDuck (IRB) shop. sorry cant remember the name.
There is a bloke in there that has done heaps of dattos, both for other people and for himself.
If you wanna see mine I am at Eight Mile Plains,
hope this helps
mely
s354218@student.uq.edu.au
Posted on: 2003/4/20 9:03
From Brisbane, Australia
go with the stanza struts and brakes. Not only will you be able to run your 15s without the illegal spacers, but you will also make your car handle and stop better too. there's 3 good reasons.
There's plenty of discussions here about the conversion, and it really all bolts in - not much messing around at all. The only question mark for the 120Y is wether the Stanza castor rod needs to be modified to get the castor 'correct'.
Posted on: 2003/4/22 2:03
Not too shy to talk
From brissy & sometimes melbourne
Would that be the same case if trying to fit in to a 1200 ute?
Posted on: 2003/4/23 13:42
I need a ute to tow my boat
From Melbourne, Australia
here char
install into 1200
should be quite similar to 120y aside from castor rods as previously mentioned, i think you will be able to use stanza top spring perch, but if not 120y one will do the job
id suggest in both cases to get lowered stanza springs, i have since found the 1200 ones combined with the longer strut raise the car and give positive camber (causes understeer)
Posted on: 2003/4/26 13:19
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
