dellow g-box and a15
From gold coast
serviced my ute today...for starters the dellow catalog says the 2t-3t hold 2.2 liters of oil...mine only held i 1.6 ruffly....then the datsun manual said the a15 holds 3.2 liters of oil with a oil filter change (which i did put a new one on)....my engine took 3.5 to get it half way up the dip stick....any reasons why? cheers
Posted on: 2007/10/30 7:02
Re: dellow g-box and a15
From Canberra
You dont want the oil halfway up the dipstick you want it no higher than the H level, or is that what you meant?
Posted on: 2007/10/30 7:03
From gold coast
haha sorry yea its just sitting on the h mark
Posted on: 2007/10/30 7:27
From Tamworth , NSW
somethings up mate, my 3t box took exactly 2.2 litres on the dot.
you pour the oil in the gearstick hole until it just starts to come out the top hole on the side.
Posted on: 2007/10/30 9:44
From gold coast
mines got a hole on the side with a big hex head nut...i filled it through there till it started coming bak out....tomoro should i pull the gear stick boot off and top it up?
Posted on: 2007/10/30 10:24
From gold coast
and wots the difference it i fill it in the side or through the gear stick?
Posted on: 2007/10/30 10:27
From Canberra
how much oil came out?
Posted on: 2007/10/30 10:28
From gold coast
it started dribbleing and the more i tryed to put in the more came out...my mates a mechanic and said if its full its full
Posted on: 2007/10/30 10:33
From perth airport
its ezy :) if the cars on flat ground and it comin out the side hole its full
Posted on: 2007/10/30 10:39
perth airport parking
Datsun 1200 ute A14
From Rustenburg (ZA)
It must just flow slowly throu the side hole
Posted on: 2007/10/30 10:46
Start with it and finish in glory
