Car will not start
Quite a regular
From canberra Australa
Hey tried to start my ute this morning and it just did not start.
It turned ova and all (until I drained my battery). I had a closer look and it seems that there is no petrol getting to the carbie, so a bit buggered. Also I replaced the fuel pump about a month ago.
Makes it worse when I was in a hurry this morning and had to be somewhere. Any
Cheers Domenic
Posted on: 2007/11/12 2:07
seadat (South East Australian Datsun Community)
Re: Car will not start
From Brisbane
What kind of ignition?... Electric? points?.... ist he starter motor making any funny noisies? and burnt smell?... If you have the mechnical pump in still and blocked up just hook that up quickly and that will give you a answer on the pump.
Posted on: 2007/11/12 2:20
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From QLD
my car did the same thing a wile ago,, but i never figuered it out ,l i just left it for a bit and it was good again ,, i think it was flooded though..
Posted on: 2007/11/12 2:21
Quite a regular
Hey I still have points and a mechanical fuel pump. When I first opened up the engine bay it did smell like something was burning but could not find where it was coming from.
I recharged the battery and tried again but no thing
Posted on: 2007/11/12 2:31
From perth airport
sound ezy mate if theres no fule getting to the carbie its one of the following
1 your tank has no fule
2 your fule line is blocked
3 the fule pump is NOT working
take the fule hose off at the carbie , turn the car over ( if macanical pump ) or untill the elicrick pump starts
there should be a strong flow of fule
hope this helps
Posted on: 2007/11/12 2:35
perth airport parking
Datsun 1200 ute A14
Quite a regular
thanks will go try that now. thanks
Posted on: 2007/11/12 2:39
From perth airport
let us know wat it was
Posted on: 2007/11/12 2:41
Datsun 1200 ute A14
Quite a regular
Hey just went out and disconnected the hose into the carbie and turned the car ova and there was no fuel coming out. There is a quarter of a tank of petrol in the car, so now I am assuming the fuel pump is stuffed, just further checked and the fuel pump is leaking a bit of oil from one of the seals or something. Could that be any thing?
Also now what type of electric fuel pump is the best if I have to change it .
Posted on: 2007/11/12 2:49
From perth airport
do you have a standard a12 ?
if you want a elctric pump and you have a starndard a12 realy any pump would be ok as there arnt to manny cars wit elctric pumps wit smaller motors than yous . so go down to super cheap and there cheap pumps are around $100 . but i like the manule pumps as they run nice and quiet
my 2 cents
Posted on: 2007/11/12 3:17
Datsun 1200 ute A14
Quite a regular
Thanks 4 that. I have an a15 in there.
Posted on: 2007/11/12 3:31
