What Struts Are These?
Not too shy to talk
From Barbados
I got these struts the other day for free. The guy said they're 160J struts. Can anyone confirm?
Here's what's marked on them:
Right strut
54302W5000
8X06
ATSUGI
JAPAN
Left strut
54303W5000
8X06
ATSUGI
JAPAN
Yeah they need a bit of cleaning up but hey, I got them for free. lol
Posted on: 2007/11/14 16:01
Re: What Struts Are These?
From Burbank, CA
Look kinda like 120Y struts the calipers are hard to make out.
If they're 120Y struts... the brakes are crappy.
Maybe I'm biased, I think the stock brakes are scary if you drive faster than 35mph.
Posted on: 2007/11/14 17:19
|||\ 81 KPB310 /|||
From Albuquerque NM, USA
The closest # I could find ends with w5825
which shows to fit a late model 510(A10)
around 79 to 82?, But I think they were called stanza outside of the states. This might not help a whole lot but thought I'd throw 2 cents worth in.
Posted on: 2007/11/14 18:36
W50 is "Applied model" code for A10 (Stanza), I believe. The same suspension is used on B310 (Sunny).
See club wiki. There are many part numbers for the same car, they can even change over time.
Posted on: 2007/11/14 19:39
Not too shy to talk
From Barbados
Stanza struts are the same as B310 struts? I thought the Stanza ones carried a stiffer shock and spring. Oh well, I was going to put them on my B310 but if they're the same I may as well put them on my B210 which has all around drum brakes.
Posted on: 2007/11/15 14:34
From Quairading, Western Australia
when putting the struts on that 120Y/B210 remember to remove thr Residual Line Pressure valve out of he line that goes to the front wheels in the master cylinder
the stanza is known as a 160J in sme countries too ast the stanza was old as a Violet
Posted on: 2007/11/15 15:15
Sorry to confuse. No the struts are different. Even among B310s there are different strut part numbers.
But the B310 Japan A14/A15 models share the same suspension with the 1978-1983 A10 (Stanza/Violet/510/1600) suspension design. Most of the part numbers are W50, but not the struts.
A14/A15 JDM/USA B310s used a H85, H90 or H92 strut, among others
A10 JDM/USA used a -W76xxx strut
Posted on: 2007/11/15 18:37
