oil problem
Quite a regular
From melbourne
im losin oil pretty fast but not seeing any on the ground has my engine had it or can it be fixed cos it still goes great.
Posted on: 2007/11/18 9:23
Re: oil problem
From perth airport
sounds like its burning oil drive up a hill and put your foot down then look in your mirror if you see blue smoke , its your rings
Posted on: 2007/11/18 9:56
perth airport parking
Datsun 1200 ute A14
Re: oil problem
From Brisvegas, oz
i would agree, the oil your using maybe too thin try an oil with a higher rating
Posted on: 2007/11/18 11:42
www.camerasplus.com.au
Re: oil problem
From Christchurch NZ
How fast is pretty fast? Maybe your valveguide seals are cooked.
Posted on: 2007/11/18 19:09
Forced Induction!
Re: oil problem
Quite a regular
From melbourne
ill try going a hill tonight..im having to top it up nearly once a week...
Posted on: 2007/11/19 1:05
Re: oil problem
Once a week is a lot. I check oil maybe once a month.
Yes, perform the hill test which tests the rings under heavy load. Check for smoke when going down the hill as well (car in gear, foot off the accelerator). This tests the oil control rings.
Also perform the no-drive test: With engine warmed up, put it in nuetral with the parking brake on. Watch the tailpipe while you rap it to 4500 rpm two or three times. Don't hold the RPM, just 'blip' the pedal. If you see *any* bluish smoke, that is oil burning.
A good used 140,000 kilometer engine will show no bluish smoke in these tests. After this mileage it is common to get some bluish smoke. The A-series will still run good but eventually starts polluting with the burned oil smoke. Then it is time for new rings (a major repair job).
Posted on: 2007/11/19 1:25
Re: oil problem
Quite a regular
From melbourne
i put some decent oil in instead of the cheap stuff and did the tests u guys suggested and no smoke came out at all but the oil level didint drop either so maybe it was as simple as that
Posted on: 2007/11/20 7:49
