« 1 (2)
Re: A14 EFI MOTOR!
From Canberra
sidedraught wrote:
Lets see some pics of these A series engines with quads that "bolt up" to a turbo.
I'm not sure what you mean by "bolt up", the turbo never bolts to the inlet manifold??? The only difference I can see is a sealed airbox like kegs had on his weber setup.
Posted on: 2007/11/21 0:02
Re: A14 EFI MOTOR!
From sydney
Tyrie, what I mean by "bolt up" is the difference between an off the shelf silicone bend and hose clamp as opposed to the fabrication of a sealed airbox like Kegs had that will still need to be plumbed in with the silicone bend and hose clamp.
But you cant bolt your turbo up to your quads, which is what makes the factory EFI setup such a keenly sought after item.
I never meant to imply that you couldnt run boost with quad throttle bodies, only that the advantage of the factory EFI setup (and therefore what makes it such a sought after item) was the simplicity of plumbing in the boosted air supply.
Posted on: 2007/11/21 0:39
Re: A14 EFI MOTOR!
From Newcastle (NSW)
What I want to know is how you blokes can search, let alone read, these japanese auctions. I just get a page full of little boxes with a couple pictures. Do I need to install the japanese language to windows or something??
Posted on: 2007/11/25 10:46
Racecar spelled backwards is racecar!
Re: A14 EFI MOTOR!
go to this web site it translates it for you.
http://babelfish.yahoo.com/
All you need to do is put in the adress and select the 2 laguages.
Posted on: 2007/11/25 12:05
Re: A14 EFI MOTOR!
From Sydney, Australia
qik1000, yes, adding the japanese fonts is the answer to 'seeing' the japanese characters. Then you can more easily cut and paste them into babelfish.
Posted on: 2007/11/25 20:36
Re: A14 EFI MOTOR!
From Perth Western Australia
Install google toolbar into internet explorer - Toolbar site - it comes with a handy little botton that will translate anypage your viewing. so much easier than cutting and pasting.
Posted on: 2007/11/26 1:15
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
Re: A14 EFI MOTOR!
Japanese pages: see instructions in club wiki.
Posted on: 2007/11/26 3:17
« 1 (2)
