« 1 (2)
Re: 112 bucks!!!
From Brisbane, Australia
I could be wrong about this, but I wouldn't significantly lighten a flywheel (as per the diagram) without balancing the whole engine assembly. I certainly wouldn't do it to an engine that has already been balanced. A significant change in the mass at the very end of the crank is certain to have an impact on the engines harmonics, and you will have a lot less mass left in the flywheel to dampen those vibrations. Don't be too surprised if you have trouble with flywheel and front pulley bolts coming loose - loctite or not.
Posted on: 2003/5/1 9:30
Re: 112 bucks!!!
From Melbourne, Australia
you got RIPPED OFF D
didn't read all this cause im too busy changing my clutch for tommorow, but i got the daiken clutch kit (a-15 vanette heavy duty job) off my auto shop for $100 bucks yesterday
Posted on: 2003/5/1 10:10
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 112 bucks!!!
From Kyabram vic, aust,
yous all got ripped off!!! I got the clutch for my a12 from the tip and it cost me nothing
Posted on: 2003/5/1 10:45
Re: 112 bucks!!!
I thought you were getting a PBR crap one.
Is yours a hairy bitch like mine??
Posted on: 2003/5/1 13:40
Re: 112 bucks!!!
From Perth
I don't suppose I could get the exact numbers off the stickers on the box for these 2 new clutches can I ??
I think you both have recons........or really good mates who are selling stuff less than cost.
That or I'm getting ripped by my supplier. But I doubt that as all my other clutches I have quoted latelt I am under by a fair margin.
Posted on: 2003/5/1 15:30
Re: 112 bucks!!!
R169NHD hope that helps you against your mafia contacts
Posted on: 2003/5/1 16:05
« 1 (2)
