Sr20 Help
From Inner west nsw CAMDEN
my b210 120y, im after advice for a radiator to suit, any ideas
Posted on: 2007/12/17 9:57
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
Re: Sr20 Help
From perth airport
the siliva rad will be best . the ca rad fits nicely in 1200s and im shore the sr rad is the same size but the hose is on the other side thats the only difference ? i remember
Posted on: 2007/12/17 10:54
perth airport parking
Datsun 1200 ute A14
Re: Sr20 Help
From Gold Coast Australia
I am using the standard s13 radiator in my sr20 sunny and it is a bit wide to fit between the rails by about 30mm each side, but the hieght is not an issue and only being single core gives plenty of room to fit a thermo fan. That is for a sunny so how different the engine bays are, I don't know, but if you need and measurements I can help you out.
Posted on: 2007/12/17 13:20
SR20DET Sunny for sale, click me for details
Re: Sr20 Help
From sydney,Australia
i am using the standard s13 sr20 radiator in my 1200. it fits in nicely with no cutting or mkin of any new brackets. im also running twin thermo fans. not my choice though they were already installed when i bought it. never once did it overheat or even look like heating up and i even gave it some stick on a 34degree day.
Posted on: 2007/12/18 10:25
Re: Sr20 Help
well im running the sr20 blacktop from an s14 with clutch fan, my issue is i want to run as stock as possible and my radiator has to be on the outside of the support,
some measurements would be a great help thanks
Posted on: 2007/12/18 12:04
FAT 120Y SR20de-NOS
Re: Sr20 Help
From Newscastle, Australia
yes the s13 rad fits nicely...but im having trouble with the bottom hose fouling on the alternator. Any suggestions here please?
Posted on: 2007/12/19 3:55
Dont die wondering.....
Re: Sr20 Help
fat_120y: I will get some measurements for you tomorrow.
Converted: I was told that a TC (i think) Cortina top hose fits for the top hose for our set ups, but after buying one I found out that the alloy pipe off the motor had been cut and rewelded at a diferent angle on my motor. So not wanting to waste the hose I tried it on the bottom and it fits. I cant rmember which end it was but I trimmed maybe 10-15mm off to get it fitting better. Hope that is of some assistance.
Posted on: 2007/12/19 14:41
