« 1 2 (3) 4 »
Re: eta's on 1/4 mile datsun 1200 ute wit near stock ca18det
From brisbane
I have run a best time of 12.7 on street tyres with a GTi-R T28 @ 15 psi.
Matty
Posted on: 2007/12/18 19:54
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Brisbane
mine was a 12.8@ 109, T25g, 3" ex, fmic, mines chip, 13psi.
Posted on: 2007/12/18 22:21
From Brisbane, Australia
perthute wrote:
hmmm i think 13.5 is a bit slow ?
my stock 180sx sr20det did a 13.5 i know ca18det arent as good but the weaight difference is huge ,
im left scraching my head ?
stock 180SX's certainly ain't 13 sec cars!!! more like mid 14s... on a good day!
Posted on: 2007/12/18 23:35
From perth airport
my 180sx is stock,stock turbo stock ecu ect ect
has a fmic and on full boost for the drag
i call that stock every one has fmic
Posted on: 2007/12/19 0:41
perth airport parking
Datsun 1200 ute A14
sorry, forgot how turbo owners work for a mintue there.
Posted on: 2007/12/19 0:59
From perth airport
stock 180sx sr20det but with a fmic and full boost= 13.5 quarter mile / datto stock ca18det with fmic and full boost = ????????
i class modified as parts like turbo injectors fule pump forged pistons head work .
if a car has fmic or pod filter / milo tin i dont class it has a modified car .
every one is different tho
Posted on: 2007/12/19 1:47
Datsun 1200 ute A14
wtf is "full boost"
Posted on: 2007/12/19 5:08
From perth airport
theres a vac line that goes to the turbo if you block it off the turbo gets as much psi has it makes . i block it off with a lil screw
we put a boost gauge on the sr20 and it made over 18 psi
the same line that i block to get full boost is the same one that people hook there boost bleed valves too
does that clear it up ?
Posted on: 2007/12/19 5:23
Datsun 1200 ute A14
From SE Melbourne
But surely 1/4 miles have to do with more than engine power....like suspension and tyres....that could be the difference between some of the more modern cars.
Posted on: 2007/12/19 5:49
Mildman, Datsunless
18psi is way too much for a stock turbo/injector combination on an SR20. Have you had the car on a dyno to check mixtures at this boost level? I'm guessing it will be very lean.
Posted on: 2007/12/19 7:28
« 1 2 (3) 4 »
