« 1 2 3 (4)
Re: eta's on 1/4 mile datsun 1200 ute wit near stock ca18det
From perth airport
had it for a year on full boost
neva dyno . as long as theres no detonation i reckon its ok
Posted on: 2007/12/19 9:20
perth airport parking
Datsun 1200 ute A14
From Brisbane, Australia
perthute wrote:
theres a vac line that goes to the turbo if you block it off the turbo gets as much psi has it makes . i block it off with a lil screw
we put a boost gauge on the sr20 and it made over 18 psi
the same line that i block to get full boost is the same one that people hook there boost bleed valves too
does that clear it up ?
vacuum line you say? lol
nah, it sounds like a very sensible mod. Makes you wonder why Nissan bothered having a wastegate at all.
Posted on: 2007/12/19 23:38
From perth airport
a lot of people run full boost just for the drag strip
if you think of all the monie you need to spend to make a sr20det go quick ( eazy 5 grand ) where i can just turn up the boost and run good times , if i blow a hole in a piston ect ect parts are cheap
so you might think its dumb but i think its a very smart mod as long as you under stand it can go wrong , but all fast cars can have things break .
has i have said before full boost for one year did 15000kms and nothing when wrong .
on the ca18det i might only use full boost just for the drags as ca18dets are getting rare compaired to sr20s
Posted on: 2007/12/20 0:38
Datsun 1200 ute A14
« 1 2 3 (4)
