5spd Gearbox
Not too shy to talk
Help me clarify...A 'Dog-Leg' 5spd has 1st and Reverse inline, correct? I recently aquired a junk '78(?) B210 with a 5spd with 1st and R inline.
Are they worth while gearboxes?
What are the benefits over a standard pattern 5spd?
What are the negatives compared to a std pattern 5spd?
Posted on: 2008/2/3 13:50
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting..."holy ####...what a ride!""
Re: 5spd Gearbox
From In front, and pulling away.Sometimes around Sydney....ish!
Dog leg boxes were originally for race applications as 1st was used only to start the race, but the 4-5 shift was a straight line. A standard 5 speed shift pattern is better on the street due to the traffic and constant 1-2 changes.
Hope this helps.
Posted on: 2008/2/3 14:29
Lifes good when your on BOOST!
Re: 5spd Gearbox
From NZ
Ratios and Strength is same between 60A and 60L box. Dogleg (in NZ at least) was matched to the B310 A14. Std pattern came with the facelift B310 and A15.
Posted on: 2008/2/4 9:42
Re: 5spd Gearbox
Not too shy to talk
So the only REAL difference is the shift pattern?
I guess if I decide to use it, I will have to pay attention so I dont back into anyone when the light turns green...LOL
Posted on: 2008/2/4 13:11
Re: 5spd Gearbox
That is a real difference, but not the only one. The '78 B210 5-speed is a very heavy, very large transmission compared to the '79 B310 model. The original Datsun 1200 5-speed is lighter and smaller than either of those.
Posted on: 2008/2/4 17:36
Re: 5spd Gearbox
From Christchurch NZ
Once you get used to them, I find I actually prefer them. The only bugger is that in my sh1tbox work truck I'm always trying to select fifth gear when I'm already in it, and grind reverse.
Posted on: 2008/2/4 19:32
Forced Induction!
