exhaust gas temps
From brisbane
Gday fellas, I was supposed to be getting info for a uni project from ford, but they dropped me on my head. I am doing waste heat recovery using thermoelectric a generator.
For an injected family sedan I need:
->exhaust gas temp & flow rate
->radiator inlet temp & flow rate
This info for any car is fine 4 now, or any leads on where the info can be found. All the uni journals will give me component temps but not gas temps. I havent looked for coolent temps yet.
Thanks fellas
mely
Posted on: 2003/5/12 4:21
Re: exhaust gas temps
From Millgrove Vic OZ
Its not the sort of thing that is normally meaured in a normal performance area. I can see the point of trying to get the data! I would be a damn interesting project!
What sort of thermo recovery system are you using, Di-electric?
Posted on: 2003/5/12 15:37
From brisbane
Yep, bismuth telluride thermocouple, that makes a 8A 1.65V 14W thermoelectric generator. 13 of em, replaces the muffler and the alternator. Works fine, have to prove it does for the write up!!!
Not to matter I am just gunna submit my own measured exhaust temps, not ones from spec sheets.
Mely
Posted on: 2003/5/13 9:47
Pity cause Mazda would be interested in something better than its restricted mufflers for their otherwise noisy hi po rotaries.
I had 5 mufflers on my pp r100.
Posted on: 2003/5/13 10:11
Hey D. On the later rx7's mazda used a valve in the exhaust so that it opened up a less restrictive exhaust path at high revs but kept quiet at low revs.
Posted on: 2003/5/13 12:33
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Hey D wqas your R100 white with big wing???? about 10 years ago?????
Posted on: 2003/5/13 14:14
No boring red with modded box flares for the 10 inch rears and 8 fronts with escort type boot spoiler. Oh and the rank rotary sticker how could i forget.
Posted on: 2003/5/14 1:11
