Re: how dificult to get approx 100-120hp out of an a12?
A10 stroke is 59mm so the rods must be really short. They could mayb be too short unless using a custom piston and also the a10 rods Ive read somewhere are forged and cheap for low compression alternative when fitted on turboed a12s.
Posted on: 2003/5/16 2:49
From Pakistan
what compression can we expect in a A12 with A10 rods?
barpk
Posted on: 2003/5/16 16:51
STRONG IS STRONGEST ALONE. PERIOD
From Melbourne, Australia
Can someone answer my question simply
yeah or ney?
Posted on: 2003/5/17 9:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Charlotte NC USA
simply probably no. the crank may not clear the bottom of the cylinder skirts and the shorter rods may put the pistons too close to the counterweights.
Posted on: 2003/5/17 10:11
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
So by slapping a14 pistons onto a12 crank and rods, giving effectily 1300cc, with a shaved head, extractors and either a 32/36 dgv or dual carbs, and possibly and electronic ignition kit, t would be feasible and cost effective for approx 100 hp, and depending on tuning, even at the wheels.
Posted on: 2003/5/19 3:30
From Auckland N.Z
theres a lot of difference between 100 flywheel hp and 100 rear wheel hp (about 20-25hp). a lighten and balance wouldnt hurt while your at it. it will make it smoother and rev easer and freer.
Posted on: 2003/5/19 13:19
very easy and cheap to get 100hp at fly from a-15!
Posted on: 2003/5/19 14:08
1200 Coupe Rallycar
From Christchurch New Zealand
yeah i know that the datto 1200sss in NZ has 89hp std
Posted on: 2003/5/20 7:09
"If your not living on the edge your taking up too much space" Rod Millen
I spoke with my datsun sense and he said an a-12 is capible of 130hp at the flywheel but he asked why bother you can easily get the power out of an a-15 and have a more reliable engine to boot. to quote him "the candle that glows twice as bright lasts half as long"
thank you sense
Posted on: 2003/5/20 11:33
Phil (aka nutcase)
I have C.L.W.E.A.
yes but this aussie idiot says, the candle that burn twice as bright has twice the fun.
Posted on: 2003/5/21 4:55
« 1 2 (3) 4 »
