help!!
From Wagga Wagga, NSW
doe anyone know whats wrong with my car? it wont start and the battery smokes when i try to start it. it makes a noise and nothing turns. thats it.
Posted on: 2008/2/27 3:12
Re: help!!
From Adelaide, S.A
Maybe it's as simple as your battery is rooted. Have you tried a different battery??..
Posted on: 2008/2/27 3:13
Re: help!!
are you sure you have hooked up the terminals correctly, pos to pos neg to neg?
Posted on: 2008/2/27 3:16
Re: help!!
battery is about 2 months old.
and it has being working for the last 2 months. and now it doesnt.
Posted on: 2008/2/27 3:17
Re: help!!
From South Brisbane, QLD
try another battery, if it works then take the battery back with your receipt and throw it at them.... If it fries your other battery and you have it hooked up properly then you have more issues...
Posted on: 2008/2/27 5:39
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
Re: help!!
Or dont. Im sure you would cop more than a battery in return.
What happens with the motor when you try to crank it over? Does it turn? Do you hear the starter motor operate? Is it only the battery that gets hot? or are the cables to the starter fried?
Posted on: 2008/2/27 5:46
Re: help!!
Not if you throw the battery at the right part of the body and RUN... ok, it was a figure of speech, not to be taken literally... its just what I feel like doing sometimes...
Posted on: 2008/2/27 5:52
Skyline Productions
Re: help!!
the motor doesnt really do anything now, it just does like half a turn and then stops. i tihnk its the cable at the terminal thats smoking. the battery is fine.
Posted on: 2008/2/27 5:53
Re: help!!
So clean and tighten the battery terminals and give it another go.
If smoking still, find where the heat is located.
If nothing happens, recharge your battery and retry.
Posted on: 2008/2/27 7:36
Re: help!!
From Southern Highlands, NSW, Australia
I'd be fairly concerned if there is smoke coming from the terminals, it takes a lot of current to get things that hot. I'd be checking for short circuits in the starter motor.
Posted on: 2008/2/27 7:43
'72 1200 sedan hillclimb/supersprint car
